Author: Subject: 8v block 16 v head
bracey
posted on 9/4/07 at 06:12 PM Reply With Quote
8v block 16 v head
would the head of a red top engine fit the block of a 8v ohc what would have to be considered ? and is it worth it
cheers
bracey
oadamo
posted on 9/4/07 at 06:14 PM Reply With Quote
i dont no if will fit but it would be a lot of messing about.you might as well fit the whole engine or turbo the one you have if your after more power
adam
liam.mccaffrey
posted on 9/4/07 at 06:21 PM Reply With Quote
itmight be the same block, but its more trouble than its worth unless your into that sort of thing
Build Blog
Build Photo Album
bracey
just curious as can get c20xe engine for nicks but needs bottom end work
oadamo
posted on 9/4/07 at 06:48 PM Reply With Quote
you could buy a gasket and see if they line up
adam
ned
posted on 9/4/07 at 08:49 PM Reply With Quote
It will fit but there are a few differences in the bottom ends of the 8v and 16v and imho they were made differently for a reason. 8v has lower compression cast pistons and fewer flywheel bolts onto the crank (6 opposed to 8). Think there is an oil relief valve aswell iirc. Don't know how much these come into play when you start making more power with an xe head on.
It can and has been done, mainly for competition where you have to retain the standard production block in a class (eg a manta or other 8v car with the same block)
I'm sure nsdev or stu16v will know of someone who's done it...
Ned.
beware, I've got yellow skin
NS Dev
posted on 10/4/07 at 11:22 AM Reply With Quote
I know of someone that has done it with an 1800 8 valve (again to fit the regs in a sprint series needing original block, so used manta 1800 ohc block which is the same as the 2.0 basically)
Its a lot of work and decent 16v bottom ends are worth little anyway.
What does the 16v need? I have a decent crank, rods and std pistons going cheap if you need em? Might have a block but don't know as I can't think where my spare ones went!!
posted on 10/4/07 at 02:16 PM Reply With Quote
Also take into account that you will need an exhaust and inlet manifold to suit the 16v head. The 16v is a great engine, but as you are going to have to change quite a few bits and pieces to get in anway, it would make sense to start with a decent engine rather than a bitsa.
Ghee60
posted on 11/4/07 at 10:31 AM Reply With Quote
i too would just start with a 16v
NS Dev
posted on 11/4/07 at 11:43 AM Reply With Quote
re the above, I now have a late (1994) Xe complete bottom end which I will take £100 for, in vgc
[Edited on 11/4/07 by NS Dev]
