<<  1    2  >>
Author: Subject: Engine Problem
d mac2b7
posted on 11/4/07 at 07:08 AM Reply With Quote
Engine Problem
Help. Can't get the engine in my Hood to run for more than 5 miles without breaking down. Its a Pinto engine & I've been trying to fix this for ages. Fitted a new ignition coil & amplifier over the winter, but no joy...
Big Dave
Mr Whippy
posted on 11/4/07 at 07:10 AM Reply With Quote
Far to vague, what’s the symptoms?
ned
posted on 11/4/07 at 07:24 AM Reply With Quote
que hellfire & co
beware, I've got yellow skin
dilley
posted on 11/4/07 at 07:28 AM Reply With Quote
sounds like a fueling problem from your description.
Mr Whippy
posted on 11/4/07 at 07:32 AM Reply With Quote
or carb icing
d mac2b7
posted on 11/4/07 at 07:43 AM Reply With Quote
Chaps, Starts to run really rough,will only accelerate, then with a big puff of smoke from the carb stalls. Will usually restart after a few mins, but will only do this 2 or 3 times before a tow home is required.
Engine is a 2.1 Pinto Vulcan unit 38 Dgas carb
d mac2b7
posted on 11/4/07 at 07:45 AM Reply With Quote
Coil, fuel pump, fuel filter are all new
d mac2b7
posted on 11/4/07 at 07:50 AM Reply With Quote
Should have said that engine had these symptoms before new parts were fitted.
How do I check for card icing?
posted on 11/4/07 at 07:59 AM Reply With Quote
it is likley to be one of two things:
1. ignition
2. fuel.
by doing simple tests when engine has stopped running can narrow it down - see any haynes manaul for trouble shooting electrics and fuel - too much for me to go over.
have you checked you have a spark when broken down?
will engine stop runing when not driven?
is fuel getting to the engine?
if you remove fule filler, does it hiss? (would indicate not vented thus preventing fuel getting to carbs)
and so on etc.
DarrenW
posted on 11/4/07 at 08:05 AM Reply With Quote
It wont be carb icing. I have a very similar set up and even in the coldest weather this year (and last) have not experienced icing. Mine starts easily even with the choke unit removed from my 38DGAS.
Have you checked the timing advance? I have also experienced a puff from the carb when i was messing with advance settings. IIRC it happened when i advanced it too much at idle. Try 10deg at 900rpm or so and see if that makes it better.
Is your head modified? If so how and what cam?
Was the carb from a RS2000 or V6? Do you know if it was jetted properly for a 2.0?
Last year i did have terrible problems with the ignition. Was a real b@st@rd to trace. It turned out to be the ignition amplifier, a brand new intermotor unit failed, since swapped for 2nd hand motorcraft and no more troubles (i also mounted on large ali panel for heatsink). More recently i have had a suspected coil break down. Ive now switched to MJLJ. My ignition was the early sierra electronic (inductive).
Just out of curiosity - you arent using a hall effect electronic dizzy are you? Has the car ever ran right or just started its troubles?
nige
posted on 11/4/07 at 08:06 AM Reply With Quote
problem
mate if you put a location in your profile
someone close by mite pop round a lend a hand
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
DarrenW
posted on 11/4/07 at 08:10 AM Reply With Quote
The more i read your posts the more it sounds like the same that happened to me with ignition amp. Of course i dont know yet what ignition system you are using.
Mine first started to fail on way to Stoneleigh last year. I wrongly diagnosed the problem as heat soak evaporating the fuel. I always had to wait a few minutes with bonnet off, once cooled down car would start and run. Eventually it stopped after shorter and shorter distances then nothing at all. Changed the amp - sorted.
Im assuming you have enjoyed your car on the road for some time and this is a new fault - ie not something that has never been fixed.
posted on 11/4/07 at 08:15 AM Reply With Quote
Have you checked the valve clearances recently? Traced similar symptoms on a friends car down to zero clearances on a few of the exhaust valves. There was enough compression to start and run, but as it heated up it ran more and more roughly until it wouldn't idle.
d mac2b7
posted on 11/4/07 at 08:19 AM Reply With Quote
Thanks for the prompt replies
This is not a recent problem. Have only managed 870miles since finished build in 2003!! I have the Sierra inductive ignition and have changed the amp and the coil, but no joy. The amp in on a large alum plate, with heatsink paste, so hopefully its not it. The only thing I have not changed is the dissy. Could it be the bob weights sticking? The cap and rotor arm were new in 2003! The lead were new last year!!
d mac2b7
posted on 11/4/07 at 08:26 AM Reply With Quote
Oh I'm in Glasgow, South Side
d mac2b7
posted on 11/4/07 at 08:30 AM Reply With Quote
DarrenW, Read your post a while a go about changing the amp. Thought I was sorted!!
tricky262000
posted on 11/4/07 at 08:52 AM Reply With Quote
I am also running a 2.1 pinto with 38 dgas i had problems with mine found that 1 of the mixture screws was wrong, changed it and play with the mixture didn't use anything to set it up did it by ear.
Think i turned both screws right in then out by a 1 and half turns each, then try and start it if it won't start another quarter turn on each keep doing this process then when it starts try reving it if it miss then turn another quarter eventually it should rev smoothly, well it worked for me.
Richard
DarrenW
posted on 11/4/07 at 09:15 AM Reply With Quote
Here is a good guide on setting the 38DGAS if it helps.
http://www.redlineweber.com/html/Tech/38_dgas_tunning.htm
posted on 11/4/07 at 09:50 AM Reply With Quote
While I suspect this is fuel related before doing anything next time it cuts out check you have a spark --- work out was wrong using logic not the change everything in sight approach.
Is the fuel tank properly vented ? -- try removing the pertol cap when it stalls.
Also have you checked there is no free floating debris in the tank that could block the tank suction. ?
[Edited on 11/4/07 by britishtrident]
d mac2b7
posted on 11/4/07 at 10:00 AM Reply With Quote
Tank has a vent fitted,(cant get any fuel in without the vent!!) although I have not removed the cap after it stops, there is always fuel in the filter before the carb when it stops. Have emptied the tank recently and have fitted a new gauge sender and filler pipe over the winter , so had a check for debris.
nitram38
posted on 11/4/07 at 11:11 AM Reply With Quote
What about leads/plugs/points (if you have them) Radio suppressors. Could be anything!!!!!!!
NS Dev
posted on 11/4/07 at 11:52 AM Reply With Quote
from what I have read it sounds like a temperature or fuel tank problem.
Drive around near home so its not far to tow back, until it stops, then remove the fuel cap and try it again.
If that doesn't work, carry a spare ignition amp out with you, when it stops, plug the other one in, and do the same with the coil.
both coil and amp are common temperature related intermittent problems, especially coil.
NEVER assume that any new bits are good, I have fitted new but faulty plug leads (Bosch at that) several times, and it doesn't help fualt finding one bit!
d mac2b7
posted on 19/4/07 at 11:04 AM Reply With Quote
Discovered that the ign amp was not sitting flush against an alum plate being used as a heat sink. I have moved the amp altogether, but had to lenghthen the 6 wires that connect it. Now I've made it worse. Much worse. Managed to nearly weld the +ve coil connector to the body when I turned the ignition on( checking out continuity).
Now it won't start at all. Engine turns over. I get a spark. Engine only "pop pops" but does not fire. I seem to be getting all the volts required at the amp. Worried I have damaged something else now. Help
posted on 19/4/07 at 11:58 AM Reply With Quote
Sure you haven't now got the firing order out 180 degrees out ?
d mac2b7
posted on 19/4/07 at 12:40 PM Reply With Quote
I've only had the dissy cap off. Not the actual leads. Can the cap go on 180degs out?
<<  1    2  >>
