Author: Subject: silicone hose
iceman26
posted on 11/4/07 at 08:32 AM Reply With Quote
silicone hose
has anyone use the superflex silicone
hose if so how flexible is it and will it hold shape when bent into possition
also has anyone got any 25mm superflex hose they want to selll me
or know were i can get some cheep
thanks
chockymonster
posted on 11/4/07 at 08:47 AM Reply With Quote
I've used it.
It is quite flexible but if the radius of the curve is too sharp then it will kink.
It will always try and straighten itself so both ends that it's connecting to need to be fixed in some way. I'll pop out to the garage and see what I have left, I'm not sure if I used 25mm though
chockymonster
posted on 11/4/07 at 09:26 AM Reply With Quote
I only have a small bit of 32mm left.
I got mine from Merlin Motorsport.
cadebytiger
posted on 11/4/07 at 10:25 AM Reply With Quote
thinking of redoing my pluming system soon. some of the hoses are a bit worse for wear.
What is the advantage of going silicone? Is it just looks? Seems expensive to me!
Rupert
