posted on 12/4/07 at 08:16 PM |
Filling type 9 with oil?
So, engine and box in, nice.. smug? Doh!, no oil in the gearbox!
Is it possible to fill the box through the gearstick hole? I can't get at the plug on the side because of the bulkhead.
Whats a safe bet to seeing how much is in? I may be able to get the top cover off at a struggle.
Any ideas chaps??
whitestu
posted on 12/4/07 at 08:27 PM |
Dunno if the MNR is tighter for space, but I managed to fill mine in an indy using a longish bit of plastic pipe.
Stu
Fatgadget
posted on 12/4/07 at 08:33 PM |
I see no reason why not if you jack the arse right up and take your time. Incidentaly,years ago we used to fill ZF boxes with ATF ..less trickly than
the usual hypoid stuff.Made gearchanges less notchy.
posted on 12/4/07 at 08:42 PM |
Hmm, imagine a bike engine chassis with the tunnel custom built to suit the type 9 and what you get is snugger than a 3 some under the
duvet!
Stu16v
posted on 12/4/07 at 09:12 PM |
Sadly, you cant fill a type 9 through the gearbox hole...
Humbug
posted on 12/4/07 at 09:21 PM |
You could cut a hole in the side of the tunnel, top up with oil and make a little panel to cover the opening. That's what I did after quite a
lot of oil seemed to pour out the back of the gearbox while I was fitting the engine+box... I didn't want to risk it being too low on oil. The
cover is fixed with silicone sealant and 4 self-tappers, so I can use it again if necessary
[Edited on 12.04.2007 by Humbug]
caber
posted on 12/4/07 at 09:33 PM |
I am planning to cut a hole in the tunnel and stick a big blind grommet in much like a series land Rover
Caber
posted on 12/4/07 at 11:48 PM |
You could fill it through the plate bolted on top of the box, but it might be a bit hit and miss on the level.
posted on 13/4/07 at 07:04 AM |
you sure you cannot get to it? they have a square hole large grub screw thing - mine is quite awkward to get at but using the blue multi-way apnner
from halfrods, there is just enough room to get it in and swing it.
Otherwise you need to cut a side hatch.
The gearstick fits in a remote that AFAIK isn't connected to the gearbox internals.
posted on 13/4/07 at 07:15 AM |
The gearstick hole is completely isolated from the gears - can't get it in that way!
I took the cover off mine and drilled a hole in the front-right corner. I then brazed/silver-soldered a threaded boss into the hole and fitted a
brass threaded plug. One of these days I intend to fit a dipstick to the plug! (the front-right corner is the only place where a dipstick can reach
the bottom of the box without colliding with gears and stuff).
If that's too complicated, then removing the cover is your only hope - unless you cut a hole in the tunnel wall alongside the filler bung.
[Edited on 13/4/07 by David Jenkins]
DarrenW
posted on 13/4/07 at 10:02 AM |
I filled mine via the top cover and just looked carefully until oil level is to the bottom of the filler plug.
seadog
posted on 13/4/07 at 11:19 AM |
Yep, likewise. I shall be filling mine up via the same method. Picking up the top plate gasket I've had on order from Ford's this
lunchtime.
[Edited on 13/4/07 by seadog]
posted on 13/4/07 at 02:35 PM |
Hmm, imagine a bike engine chassis with the tunnel custom built to suit the type 9 and what you get is snugger than a 3 some under the duvet!
That is a bit of a squeeze! Have you had any problems running the wiring loom and brake/fuel pipes down the tunnel? Space is a bit tight in my
Striker, but I have it easy compared to you.
martyn_16v
posted on 13/4/07 at 05:42 PM |
I imagine i'm going to have similar problems, the tunnel on the new indy chassis is just as slim. I can't actually get the gearbox in and
out without taking the reverse light switch off it's that narrow Wiring and fuel/brake lines aren't too much of a problem though, they
can go along the top of the tunnel as there's plenty of room height-wise, it's just the width that's tight for me.
