omega0684
| posted on 15/4/07 at 10:02 AM |
cylinder two trouble
morning the guys,
i have been having a problem with cylinder two in my pinto running R1 carbs. there is lots of back firing and the carb for the cylinder seems as if
its choking as its spluttering all the time. all other cylinders and fine, no choking noises or puffs coming from them, any idea what it could be?
Cheers Alex
jacko
| posted on 15/4/07 at 10:08 AM |
Have the carbs been set up [ balanced ]
have you had them running ok or have you just put them on
Jacko
stevec
| posted on 15/4/07 at 10:09 AM |
Morning Alex, your up early.
If you have checked the spark is good on that cylinder.
You need to see if there is any crap in the jets on that carb. The mixture screw is correct because it was checked. Also check the float level. Did
you check the valve clearances.
Steve.
[Edited on 15/4/07 by stevec]
Marlon
| posted on 15/4/07 at 11:24 AM |
I had somthing similar a couple of weeks ago, It turned out to be my plugs that were shot.
hth.
john.
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
Ketchup
| posted on 15/4/07 at 01:31 PM |
i would def check the plugs before doing anything else
