| posted on 22/4/07 at 10:26 AM |
So what is a reasonable oil temperature?
Looking for a few opinions - I'm sure I'll find a few here...
Had a good and enthusiastic blast on the open road yesterday, and did a temp check off the side of my sump as soon as I stopped (using an IR spot
thermometer). It read 97 degrees C, measured in a couple of places on the sump.
Is this within normal operating parameters?
cheers,
mark chandler
| posted on 22/4/07 at 02:28 PM |
No problem with that, up to around 120 is normal as oil gets squirted under the very hot piston crowns etc.
Regards Mark
| posted on 22/4/07 at 02:53 PM |
Normal is about 10 degrees above water temp -- but oil temperature tends to build up during a prolonged burn up.
| posted on 22/4/07 at 03:08 PM |
That would fit - water temp is usually around 88 - 90.
