RazMan
| posted on 23/4/07 at 08:28 AM |
Silencer too quiet !!
In a frenzy of activity over the weekend I I decided to remove some of the packing from the silencer to make the V6's exhaust note a little more
sporty.
Removing the end cap I found 3 thicknesses of 6mm E-glass tightly packed in there so I removed one thickness and it now sounds a little more like a V6
should but I reckon I could take a lot more wadding out without making things unsociable.
If I take any more wadding out it will leave quite a void in the can, so would it be better to fill the whole space with something less dense or just
leave it empty?
Raz
Mr Whippy
| posted on 23/4/07 at 08:46 AM |
through all the nasty wadding in the bin, you know you want to...
Mr Whippy
| posted on 23/4/07 at 08:53 AM |
quote: Originally posted by Mr Whippy
throw all the nasty wadding in the bin, you know you want to...
can't even spell throw properly
graememk
| posted on 23/4/07 at 09:13 AM |
i did the same with my indy as well, took it all out now it sounds like a tractor lol
Mr Whippy
| posted on 23/4/07 at 09:46 AM |
Check these out that's what I have on my buggy, leave the baffles out and you have effectively two trumpets. Loud? you've no idea
RazMan
| posted on 23/4/07 at 10:05 AM |
Oooh you could cut them at different lengths and have 'full blown harmonics'
I think I'll try taking it all out then and see (hear) what happens. Thanks guys
Raz
chockymonster
| posted on 23/4/07 at 10:15 AM |
reminds me of the sidewinder on my sister's beetle, set car alarms of at 50 paces
paulf
| posted on 23/4/07 at 10:01 PM |
You may find that it affects the mapping and performance of the car. I have found that as my silencer looses wadding it gets noiser but the
performance gets less, I assume due to the flow through empty casing being different to when full of wadding and loosing the extraction effect.
Paul.
RazMan
| posted on 23/4/07 at 10:45 PM |
I whipped out most of the wadding now, just leaving a token layer to prevent any resonating that might happen with an empty can.
The sound is much fruitier now with a deeper rumble at low revs but not overly loud when redlining.
Not sure about power change but havent noticed anything so far.
Raz
