Author: Subject: RV8 EFI - cold start injector
dsapsfo1
posted on 23/4/07 at 09:06 PM Reply With Quote
Can I get away with removing the cold start injector and just blanking it off? Got a (very slight) clearance issue around the injector connector on my Viento's bonnet.....
Thanks...
Agriv8
posted on 23/4/07 at 09:38 PM Reply With Quote
I think it will throw a fault on Hotwire injection ? coid be wrong
are you running STD ecu ?
regards
Agriv8
mark chandler
posted on 23/4/07 at 10:10 PM Reply With Quote
Junk it, no real issues as the other injectors will overfuel, it only squirts for a maximum of 7 seconds, this is controlled by the rear most sensor around the thermostat housing.
Hot wire does not even have one, flappy box ECU will not even know the difference, no diagnostics on it, its an analouge based system.
Regards Mark
Agriv8
posted on 23/4/07 at 10:22 PM Reply With Quote
apologies just re-read that you are on about the cold sart injector not the air by-pass valve.
regards
agriv8
Simon
posted on 23/4/07 at 11:10 PM Reply With Quote
I took mine out and welded up the hole
But then I am doing it all slightly different!!!
Simon
ed_crouch
posted on 24/4/07 at 01:57 AM Reply With Quote
Remove it.
Most of the TVR boys do.
It only helps on a REALLY cold winter morning. Other times it just overfuels the engine.
IIRC it works in conjunction with the extra air valve in front of the plenum, and that only stays open for a few seconds.
I disconnected mine and there was no difference!
Ed.
dsapsfo1
posted on 24/4/07 at 08:30 AM Reply With Quote
Thanks for the comments guys.
Yes I am running the standard SD1 ECU.
So is it a case of just disconnecting the injectors and blanking it over? Do I need to do anything with the wiring?
Can I then remove the extra air valve as well?
[Edited on 24/4/07 by dsapsfo1]
NS Dev
posted on 24/4/07 at 12:05 PM Reply With Quote
Yea its no problem to go without it, same on the 4 cylinder bosch L jetronic setups, on my old manta (back in 1995) I pulled the cold start one out and put an extra injector in there on a turbo technics injector driver to supplement the fuelling (modified engine)
