oadamo
| posted on 25/4/07 at 09:03 PM |
rwd sump mod
hi iam using a fwd engine for rwd do you need to mod the sump or do you think ill get away with it.its a saab 2.3 turbo engine. has anyone got any
pics of the baffle plates or what mods you have done thanks adam
westcost1
| posted on 26/4/07 at 09:51 AM |
Hi im moding my sump at the moment its a 1,6 cvh engine (xr2i) there can be surge problems with the oil pickup as when the engine is turned around the
pick up front to back and should be side to side also chopping the bottom of and adding some wings to the side for that extra inch of ground clearance
have a look at this link
http://www.sylva.co.uk/technical/cvh.htm
dont now what its like on the saab?
Tarmac terrorist
| posted on 9/5/07 at 08:11 PM |
saab 2.3
hi i am thinking of using a saab 2.3 in my kit car please help what gearbox r u using and what are you doing about engine management thanks
oadamo
| posted on 9/5/07 at 08:48 PM |
(was) i went back to pick it up and it got crushed lol. iam gonna use a zetec for now.and iam gonna buy a cossie engine and rebuild it in my spare
time to a big spec. i was looking at all diffrent engines but i think in the long run ill spend as much money messing about. then its worth. but with
a cossie its all tryed and tested so iam gonna spend the money and do it propely
adam
oadamo
| posted on 9/5/07 at 08:52 PM |
if you want a standrad 2.3 saab turbo ecu. i still have it and the map sensor
i tuk em off ready for when i was gonna have the engine yours for postage cost if you want prob a fiver
adam
Tarmac terrorist
| posted on 9/5/07 at 09:12 PM |
cheers think i will ring tj motorsport up and get a price on a bellhousing then try to find a beefy modid type 9 or a t5 box if you want rid of the
2.3 i might have it what have you got for it e.g Wiring inlet manifold, exhaust ect
