Author: Subject: ground clearence
24vseven
posted on 25/4/07 at 09:53 PM Reply With Quote
ground clearence
hi folks this question might had been asked allready
what amount of clearence should i have between the ground and my sump i live in a city with lots of speed humps and dont want to wipe out my sump on the first one i come to
graememk
posted on 25/4/07 at 09:55 PM Reply With Quote
more than i have, mines 7cm..... so 10+
blakep82
posted on 25/4/07 at 09:59 PM Reply With Quote
i'm actually going for 8.5cm, i think its too low, but its gonna mess with my suspension geometry if any higher. I like the idea of hydraulic suspension though
________________________
Trev Borg
posted on 25/4/07 at 10:12 PM Reply With Quote
target to go for is 4"
should ba able to get away with 3" if your carefull
Before you judge a man, walk a mile in his shoes.
By that time, who cares.
You're a mile away, and you've got his shoes
RazMan
posted on 25/4/07 at 10:29 PM Reply With Quote
I was using 100mm and nearly wiped out my sump on the 'square' speed bumps.
120mm is just about high enough but you still need to take care over the little beggars - go between then, never over
Oh and avoid roadkill too - anything bigger than a flat squirrel makes a lot of mess to hose off later.
Raz
posted on 26/4/07 at 07:25 AM Reply With Quote
75mm is do-able but you have to be really carefully about slowing down for speed bumps and be really really careful when going over the bumps with gaps in the middle of the road- if you try and straddle that you're a gonner- your wheels don't rise much and the bump rips the sump off...
100mm+ is preferable....
flak monkey
posted on 26/4/07 at 07:27 AM Reply With Quote
I have 75mm at the moment to the sump, but am considering raising it to 100mm.
I know there would be problems with speed humps with 75mm, but what about bumpy roads? Of which there are plenty at home...
Sera
http://www.motosera.com
posted on 26/4/07 at 07:41 AM Reply With Quote
I run at a fraction over 100mm to the bottom of the bellhousing; not hit any bumps - yet.
Mr Whippy
I was looking at my Falcon last night 2" but then the sump is plated in 5mm steel and its certainly had a few thumps going by the missing paint..
