Author: Subject: best engine position ??
cjtheman
posted on 26/4/07 at 05:18 PM Reply With Quote
hi all its me again anybody know what the best position (from the front of the chassis ) to fit the pinto motor
not sure how critical it is
cheers
colin
StevieB
posted on 26/4/07 at 05:22 PM Reply With Quote
You'll be wanting it as far into the middle of the car as you can.
DIY Si
posted on 26/4/07 at 05:43 PM Reply With Quote
As far back and down as you can. It is however a compromise between sump clearance, footwell space and engine position. Ie, the further back, the less the footwell space, the lower it is, the more likely you are to bash the sump a bit.
Sun Tzu, The Art of War
mark chandler
posted on 26/4/07 at 05:44 PM Reply With Quote
Bolt on the gearbox and drag the whole lot so its just missing the bulkhead, make up mountings around this location.
Regards Mark
The Baron
posted on 26/4/07 at 08:04 PM Reply With Quote
I have a pinto & type 9 in my car. The back of the bell housing is about 1 inch from the start of the transmission tunnel. dont forget you will need a bit of space to play with as the engine will move about during acceleration and braking etc....
The Baron
cjtheman
posted on 26/4/07 at 08:19 PM Reply With Quote
thanks for your comments guys
try and have the motor bolted in this weekend
cheers
colin
lsdweb
posted on 27/4/07 at 07:42 PM Reply With Quote
Something like this ?
I know it's a Zetec but the principle is the same.
Wyn
