Author: Subject: sync rings inspection
Trev Borg
posted on 26/4/07 at 06:05 PM Reply With Quote
ok
found the sync rings
inspected them
what are they supposed to look like
they look like the ones in all the pictures i've seen. Do worn ones just look, err worn ?
Before you judge a man, walk a mile in his shoes.
By that time, who cares.
You're a mile away, and you've got his shoes
jollygreengiant
posted on 26/4/07 at 06:22 PM Reply With Quote
Errrrrrrrr, yep.
The teeth will look worn from engagement by the baulk ring AND the taper seat that the sync ring sits onto the gear taper will look worn, the taper on the synchro might also feel loose on the gear if badly worn as it is this taper that slows the gear that is being engaged to the same rotational speed as the snchro ring.
I hope this is fairly clear and helpful.
theconrodkid
posted on 26/4/07 at 06:55 PM Reply With Quote
put the baulk ring on its hub and measure the amount of hub left showing with feeler gauges,the min gap should be in the wsm
who cares who wins
pass the pork pies
Trev Borg
posted on 26/4/07 at 07:42 PM Reply With Quote
clear as mud
When i said i found them, i just meant with the top off the box.
Do I have take the bloody thing to bits to see if they are ok ?
jollygreengiant
posted on 26/4/07 at 08:07 PM Reply With Quote
Yep, thats the fun of gearboxes.
Trev Borg
posted on 26/4/07 at 09:08 PM Reply With Quote
oh FTFAGOS
me thinks i'll just try it and see if it works.
Sounds like a lot of hard work ?
DavidM
posted on 26/4/07 at 10:30 PM Reply With Quote
That's probably the best decision you'll ever make.
