Author: Subject: Polyurethane / nylon engine mounts
givemethebighammer
posted on 29/4/07 at 08:43 PM Reply With Quote
I have been using the 50mm tall transit / landrover type engine mounts from Rally Design with my zetec / tiger, but they seem to get soft quite quickly (quite a bit of engine movement new compared to when they were new 12 months ago). Does anyone know where I can get some polyurethane or nylon mounts from that look like diagram A below (M10 mounting bolts). Or should I just buy some polyurethane / nylon rod and make some stainless steel sleeves up so the mounts look like diagram B ?
givemethebighammer
posted on 29/4/07 at 08:59 PM Reply With Quote
thanks Chris,
yes I'm using the group N mounts. They were fine when I first got them but now seem to be getting a bit soft, hence the polyurethane / nylon idea.
DIY Si
posted on 29/4/07 at 09:01 PM Reply With Quote
If you do dia B but bin the inner tube, you'll be fine. Otherwise it'll just clamp down on the tube, and pretty much solid mount it.
Sun Tzu, The Art of War
viatron
posted on 29/4/07 at 09:14 PM Reply With Quote
Havent used them myself but these people were recommended to me:
http://www.rino.co.uk/products.asp?category=Anti%2DVibration&subcategory=Anti%2DVibration+Mounts&gclid=CKLZnsPt6IsCFSYSQgodDxhZVA
givemethebighammer
posted on 29/4/07 at 09:41 PM Reply With Quote
After a hour of googling for something suitable I think diagram B (minus the sleeve) is the way I'm going to have to go. I guess the next questions are nylon or polyurethane and what hardness.
I think the Rhino mounts are rubber - I'd prefer something a bit more resilient.
thanks
MkIndy7
posted on 29/4/07 at 10:00 PM Reply With Quote
I'd be careful with the Grade of Nylon/polyurathane that you get.
The engine mounts for my Tin-top were specialist ones and they would only sell you the full kit (when only 1 was split!).
We went to a local Plastic suppliers and they said "yes we've got just the stuff they use this on the Focus WRC car" and my GOD could I believe it.. the engine might as well have been bolted to the chassis it shook everything!
Whatever the hardness its measured in I think that was 90 and what i've got now is about 40-50 and its still far too hard really the engine still doesn't really move when rev'd or when load is put on it.
I'd try and stick to something commercially available as Engine mounts
