Author: Subject: 1.3 x-flow timing setting
myeates
posted on 1/5/07 at 06:52 PM Reply With Quote
hi guys does anyone know how many degrees before top dead centre the above engine should fire as mine is going at 0 so needs sorting
thanks guys
posted on 1/5/07 at 08:03 PM Reply With Quote
Depends on a lot of things --- try giving it 10 degrees BTC at idle with vac adavance disconnected.
lukefab
posted on 1/5/07 at 09:40 PM Reply With Quote
Yes I second that,did mine at the weekend and what a difference.
Disconnect vac pipe and set timing at 10 degrees BTC.
myeates
posted on 2/5/07 at 08:32 AM Reply With Quote
thanks guys 10º it is will sort this weekend
thanks again
