dsapsfo1
| posted on 3/5/07 at 06:55 PM |
Rover V8 - rev limiter?
Hi, can anyone tell me whether there will be a rev limiter on my twin-plenum Rover V8 removed from a SD1? I'm running the standard ECU etc as
removed from the car - it revs around so quick I don't want to buzz the engine! If it hasn't, I'll get shopping....
nitram38
| posted on 3/5/07 at 07:18 PM |
I have never run a limiter on a Rover V8,(not sure about racing), but don't the hydraulic tappets limit your revs?
Simon
| posted on 3/5/07 at 07:19 PM |
If you still have the standard hydraulic lifters, you shouldn't need a rev limiter as they'll "pump up" at about 5500rpm and
should prevent engine overrevving.
Hopefully, someone will confirm my longheld belief.
Simon
[Edited on 3/5/07 by Simon]
dsapsfo1
| posted on 3/5/07 at 07:20 PM |
Dunno - all I know is that it raced around to 6k without trying and I reckon you could easily get carried away without realising!
froggy
| posted on 3/5/07 at 07:37 PM |
the lifters will stop it over revving and if its an sd1 motor i wouldnt go over 5k without some bottom end work as the main caps are pretty poor and
will move around at high revs
mark chandler
| posted on 3/5/07 at 08:35 PM |
twin plenum is still flappy box ecu so no rev limit.
craig1410
| posted on 3/5/07 at 11:49 PM |
My Dad's old SD1 would easily reach 6k RPM but there's not any point in going over 5500 or so as max power is at around 5250. A rev
limiter might be a good idea but I don't think it is essential as discussed the lifters will restrict revs quite well.
Craig.
dsapsfo1
| posted on 4/5/07 at 08:21 AM |
Thanks for the comments guys, guess I'll need to drive it a bit more and see how I go.
