Author: Subject: Oil in bell housing 2.0 XE
Pants On Fire
posted on 7/5/07 at 04:12 PM Reply With Quote
Having blatted back & forth to Stoneleigh yesterday I find oil on the garage floor this morning & oil in the bell housing, it's engine oil.
I assume it's the rear crank oil seal, can't see anywhere else it could come from.
It's a 2.0 XE, do I need any special tools to remove & refit new? Apart from a crane/hoist!
And before anyone says whilst it's out stick a blade in there, I had thought of that
Yes, I am an agent of Satan, but my duties are largely ceremonial.
chriscook
posted on 7/5/07 at 04:24 PM Reply With Quote
Apart from a long breaker bar to get the flywheel bolts undone I can't think of anything - other than ideally a clutch alignment tool. Don't forget to use new flywheel bolts too.
b184
posted on 7/5/07 at 05:30 PM Reply With Quote
Oil in bell housing
possibly front gearbox seal?
posted on 7/5/07 at 06:39 PM Reply With Quote
Check the breather system !
ned
posted on 7/5/07 at 08:21 PM Reply With Quote
IIRC there is a vx assembly sealant for the joining faces of the end bearing cap that the seal sits under.
Ned.
beware, I've got yellow skin
Leon B
posted on 7/5/07 at 09:27 PM Reply With Quote
Def use the correct VX sealant to fit the new rear crank seal, Ive had big probs with this is the passed through not using the recommended sealant.
Pants On Fire
posted on 8/5/07 at 07:29 AM Reply With Quote
Thanks guys, off to the local VX stealer this morning to get the parts & sealant. Might have a look for a lightened flywheel on fleabay whilst its all out.
ned
posted on 8/5/07 at 08:07 AM Reply With Quote
Be wary of overlightened standard flywheels, if you can find a nice steel one all the better
Pants On Fire
posted on 9/5/07 at 01:14 PM Reply With Quote
The only 'over lightened' flywheels I've found so far are the later pot type, mine's flat and overly heavy.
