cadebytiger
| posted on 10/5/07 at 01:17 PM |
spanish carbs
I have the spanish type of weber 45 on my pinto which has an idle airbleed skrew as well as a fuel mix skrew.
Does anyone know the best method for setting idle on these? I guess you need to balance the air flow in running through each carb with the mix set the
same on each and then go onto get the best mix but where do i start with the air bleed?
Thanks once again
Rupert
flak monkey
| posted on 10/5/07 at 06:33 PM |
It tells you how in the 'How to powertune weber and dellorto DCOE/DHLA carbs' book by des hamil. But mines at home. Sure someones got a
copy to hand though.
Sera
http://www.motosera.com
cadebytiger
| posted on 10/5/07 at 10:05 PM |
yep got that book. will have a read and stop being lazy! Thanks again
