Author: Subject: Roller/high lift rockers
thepest
posted on 11/5/07 at 08:08 AM Reply With Quote
Hi everyone, has anyone used high lkift roller rockers on the crossflow? Whats the difference to just having a high lift cam? Does the wear of the tappets reduce that much or is it just a myth?
I know they are expensive but is there any realistic gain towards them?
thunderace
posted on 11/5/07 at 08:17 AM Reply With Quote
i would say no unless its for track use are you lookng at the piper one on ebay ? you would need a a9 cosworth cam or something like it to use it but it would be no good for normal road use.
posted on 11/5/07 at 09:24 AM Reply With Quote
If anything the cam and tappets (i.e. cam followers) will wear more with high lift rockers as the forces on them will be higher.
The advantage of the roller rockers is that it eliminates sideways forces on the valve stem, which can become quite large with high valve lifts and cause premature guide wear.
Memphis Twin
posted on 12/5/07 at 10:20 AM Reply With Quote
Yes, I used them on my Hillclimb/Sprint x-flow Striker to uprate the 1FR4 Kent rally cam. It saves taking the engine out to fit a different cam, but if I was doing it again I probably wouldn't bother; I would just select a higher lift, longer duration cam to begin with.
High lift rockers can really only be used with moderate valve lift cams (10-11mm max) otherwise you'll run into coil binding problems with your valve springs and other horrors.
