davrus
| posted on 11/5/07 at 08:59 AM |
Crossflow breathers
For those with a crossflow engine, what have you done with your breathers off your carb to get max performance, have you blocked them, connected them
to somthing else or what.
Mine is a 1300 with a twin choke webber if that helps.
All advise greatly received.
Many thanks
Dave
[Edited on 11-5-07 by davrus]
Check out my website http://www.thedave.co.uk/
Feel free to sign my guest book in the links page.
Marcus
| posted on 11/5/07 at 11:24 AM |
Left mine as standard. May be fitting a catch tank with new engine though.
Marcus
Because kits are for girls!!
davrus
| posted on 11/5/07 at 05:00 PM |
Left as standard? have you used the original air filter box then of connected them to another one.
Marcus
| posted on 12/5/07 at 09:23 AM |
Now that you've mentioned it, it's not quite standard!!
It's so long since I did it, I forgot!!
All I've done is taken the breather to the inlet manifold, an elbow was used rather than a tee at the manifold end.
HTH
Marcus
