kenton
| posted on 11/5/07 at 03:53 PM |
rv8 core plugs
Hi
Im changing them at the moment, the ones on the side are no problem but the two behind the flywheel will only knock in about 5mm before they hit
something.
Should i be removing then in a different way other than the usual, tap in, rotate, pull out?
thanks kenton
| posted on 11/5/07 at 04:00 PM |
Dril hole for large self tapping screw and use it to lever/pull them out other wise just careful use of a small cold chisel or marlin spike.
[Edited on 11/5/07 by britishtrident]
[I] What use our work, Bennet, if we cannot care for those we love? .
DIY Si
| posted on 11/5/07 at 04:12 PM |
Or a small bladed screw driver, if like me you don't have a cold chisel handy! Bash it through and lever it out, or self tappers as per BT.
Let your plans be dark and as impenetratable as night, and when you move, fall like a thunderbolt.
Sun Tzu, The Art of War
