edspurrier
| posted on 12/5/07 at 06:56 PM |
Clutch Stuck (Zetec, Type 9)
Finally put Zetec in. Clutch and release bearing are Sierra, as supplied by Tiger. Spigot bearing fitted.
tried to push clutch forward to test it. Arm wobbles a bit, but it's stuck.
Any ideas? Or am I just not pushing hard enough?
TangoMan
| posted on 12/5/07 at 07:03 PM |
You won't push it by hand. Try using a lever as the spring tension is very strong.
Bear in mind how hard it is to push the clutch with your foot!!
[Edited on 12/5/07 by TangoMan]
Summer's here!!!!
edspurrier
| posted on 13/5/07 at 11:29 AM |
Good, that's what I thought
