jambo
| posted on 12/5/07 at 09:06 PM |
water temp?
hello
my car is running at a temprature of about 95 98 deg c and when i chase it on a little at 90mph(on private road)it is rising to 105 deg is this to
much and if so whats going to happen.
the engine is the sierra twin cam injection with pressurised sierra water system.
zetec
| posted on 12/5/07 at 10:08 PM |
90-95 in normal running is fine, not sure why it should go up with speed. Have you used a new rad? Have you tried a new thermostat?
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
RazMan
| posted on 12/5/07 at 10:32 PM |
If the temp is rising when going at faster speeds it probably means that the air to the rad needs ducting or some other airflow issue. 90-95 is about
right for average operating temp.
[Edited on 12-5-07 by RazMan]
Raz
TangoMan
| posted on 13/5/07 at 06:37 AM |
With a good pressured system, 105 should be OK for short periods.
Does it get hot when you boot it or when you slow down afterwards?
Summer's here!!!!
| posted on 13/5/07 at 07:55 AM |
In a presurised system water boils at about 115c.
As "The Razs" says the increase is due to an airflow or raddiator fin area issue.
One problem with Seven style bodwork is getting the hot air out the engine compartment.
It might help a bit to fit a lower rated thermostat -- the heat will still build up but at least it will start from a lower temperature .
d mac2b7
| posted on 13/5/07 at 08:19 AM |
You could fit a thermostat with a lower opening temp to give you a better chance of cooler running when pushing on!! I know you can get various
different temp thermostats for the SOHC Pinto. Not sure about the DOHC version. I used a modified Nissan stat rated at 79°C
Nice Hood
| posted on 13/5/07 at 09:19 AM |
Water wetter will drop the temperature
jambo
| posted on 14/5/07 at 01:08 PM |
thanks for the answers lads,looks like i will have to get it down a bit.
the problem is from the new grill i have put on and the turbulant air at greater speed must not be letting just enough air through. the problem is
mostly on the mway like travelling back from stoneleigh
98 to 105 all the way 300 miles.
i will try and improve the ducting
dave r
| posted on 14/5/07 at 08:29 PM |
is the rad well shielded, so the air has to go thru it ?
mine ran hot till i made the air got thru the rad instead of around and over it
stevebubs
| posted on 14/5/07 at 10:59 PM |
noddy question; are you sure you've got all the airlocks out?
