myeates
posted on 14/5/07 at 12:25 PM |
where to get a cheap hose joiner
hi does anyone know where i can get a cheap hose joiner with a threaded part on side for take off
or a reducing t-piece to fit 32mm hose down to fit 15mm hose
or even a self sealing take off to fit 32mm hose
need to get me expansion tank plumbing in right all the ones ive found from the usual are either too big or too expensive
regards
mark
ayoungman
posted on 14/5/07 at 12:43 PM |
plumbers merchants will do the later. Solder up what you need. what sort of threade take off? Oil feed or pressure sender maybe ? Give us some more
info on this please
"just like that !"
nib1980
posted on 14/5/07 at 12:58 PM |
Try Car builder solutions, ( google them) they can make bits up if you phone then and there usually a good price
bodger
posted on 14/5/07 at 01:01 PM |
AllyFab sorted me out with a custom made T-Piece (32mm with 15mm angled T) for £14 + postage (Picked mine up from him at Stoneleigh). Nice guy to deal
with.
By the way Stainless Vacuum cleaner extension pipe is 32mm & available off ebay dirt cheap. Chromed steel clothes rails are 25mm & lots of
ally tube at B&Q. Get inventive ![](/images//smilies/smile.gif)
posted on 14/5/07 at 02:19 PM |
I'll 2nd Car Builder Solutions
They sell exactly what you're after off the shelf no more than £15 delivered IIRC.
myeates
posted on 14/5/07 at 02:38 PM |
thanks guys its just a take off to go back to the expansion tank as at the moment i have the tank plumbed in at the water pump so the tank fills up
when you put some high revs on. will give car builders a ring is there a web site for the ally fad people
regards
mark
bodger
posted on 14/5/07 at 03:48 PM |
AllyFab
myeates
posted on 14/5/07 at 04:36 PM |
thanks getting one made seem quite good thanks guys
RazMan
posted on 14/5/07 at 06:16 PM |
Here's one (of several) that CBS made for me. Very reasonable and good quality.
![](/galpreviews/a557846-Heater tee.jpg) ![Rescued attachment Heater tee.jpg](/gallery/a557846-Heater tee.jpg) Rescued attachment Heater tee.jpg
Raz
myeates
posted on 18/5/07 at 10:21 AM |
got one now made out of stainless will do the job ![](/images//smilies/bigsmile.gif)
