bodger
| posted on 16/5/07 at 09:03 AM |
50mm - 60mm exhaust adapter
How do you get from a 2" pipe to the 60mm inlet on an R1 exhaust. Anyone got a link to a supplier?
Looked at the Jetex catalogue but can't see anything suitable.
GeoffT
| posted on 16/5/07 at 09:25 AM |
A while ago now, but I think I used their 50.8/57/63.5 stepped sleeve. Cut off the 63.5 part, the 57 section is a good fit inside the R1 pipe. Welded
this in place, which leaves a 50.8 section to connect to. As I say all from memory, I'll double check the dimensions if you wanna try
this....
Edited to confirm I used the Jetex U076320 stepped sleeve, but as stated you'll need to cut off the 63.5mm section.
[Edited on 16/5/07 by GeoffT]
wicket
| posted on 16/5/07 at 12:36 PM |
Pipecraft (Lancing, West Susex) will make you one for not much money. I had my exhaust parts made by them and am really pleased with what they did for
me.
Talk to the production manager Andy Woods on 07961 901580, DON'T use works phone number.
Just down the road from you, he will probally do it while you wait.
http://www.pipecraft.co.uk/
[Edited on 16/5/07 by wicket]
bodger
| posted on 16/5/07 at 12:51 PM |
cheers wicket sounds perfect.
