Author: Subject: Supercharging
jonno
posted on 19/5/07 at 06:18 PM Reply With Quote
Supercharging
Hi all, i've been collecting bits for my 1.8 zetec project, ZX9 carbs, megajolt etc but i keep thinking about supercharging it.
Do you think i could use the ZX9's and megajolt with a supercharger ?
Or does it make more sense to use a single 2.0 throttle body and use megasquirt ? (more expense and i've already got the other bits !)
Anyone with supercharging experiance ?
takumi
posted on 19/5/07 at 06:35 PM Reply With Quote
Yep,
I saw a turbocharged ZZR seven at Snetterton TotalKitCarLive, which just ran on programmable ignition and std carbs and using the std airbox, carbs likely to be jetted to run richer than normal, probably a 1.7-1.8mm mainjet and the needles lifted up 1 slot.
Bike carbs on a std car engine will need a main jet around 1.6-1.75mm, if supercharing maybe think of 1.7-1.8mm..
just an idea,
atb
tak
[Edited on 19-5-07 by takumi]
RobinHood 2B 2.0i pinto, Keihin 38mm Carbs, lightened flywheel, O'Mori remote filter kit, 10 row oil cooler. Modified head, 10.2cr, special valves FR22 cam, 4- 1 header.
paulf
posted on 19/5/07 at 08:24 PM Reply With Quote
If your using megajolt you will need a MAP sensor version for use with forced induction, TPS can not be used as it cant indicate the load under boost.
Paul.
takumi
posted on 20/5/07 at 01:06 PM Reply With Quote
w/ref to supercharging, you probably could use just a TPS, as boost is rpm linked not throttle/rpm as with a turbocharger system.
For example: Boost at 3k will be the same wether throttle is 50% or 100%..
posted on 20/5/07 at 01:26 PM Reply With Quote
Boost will not be the same at all throttle openings (otherwise throttle wouldn't be very effective!), but you are correct that boost should be predictable given engine RPM and throttle opening, at least far more so than a turbocharged engine would be.
jonno
posted on 20/5/07 at 11:14 PM Reply With Quote
Looks like i'm going to keep i eye out for supercharger bits now I've got megajolt with tps so i'll see what its like with that (might change to map if its that bad)
Thanks for advise help so far
omega0684
posted on 21/5/07 at 09:54 PM Reply With Quote
dont mean to hijack the thread but what is tps?
iank
posted on 21/5/07 at 09:58 PM Reply With Quote
throttle position sensor. provides a value depending on how far you've pressed the accelerator.
[Edited on 21/5/07 by iank]
Anonymous
