omega0684
| posted on 20/5/07 at 09:02 PM |
running trouble
evening all,
after working all weekend on the car, i have come on leaps and bounds towards booking my sva. (i reckon that i might get the paper work sent off on
tomorrow.
i have managed to get 90% of the dash wiring complete and i thought that i would take it out for a trip to the top of the street and back just to make
sure that the gauges and other instruments were working.
here the problems start. as i started to pull off everything seemed fine got up to about 3500 rpm in first gear and there just seemed to be no more
power! the revs went through the roof on the accelerator but the was no pull in the car, it was only moving out of momentum.
i shifted down into 2nd and as the revs dropped back down to around 2000rpm the power came back, but then the same happened again, as the revs
incresed to 3000-3500 the power went and momentum took over!
any ideas on what may be causing the lack of power?
cheers fella's
Alex
flak monkey
| posted on 20/5/07 at 09:04 PM |
If the engines is still picking up but the cars not accelerating its usually a slipping clutch...?
Sera
http://www.motosera.com
bigrich
| posted on 20/5/07 at 09:10 PM |
slipping clutch or a lot of wheelspin
| posted on 20/5/07 at 09:47 PM |
Clutch
RazMan
| posted on 20/5/07 at 09:57 PM |
It has got to be the clutch Alex
Raz
omega0684
| posted on 20/5/07 at 10:07 PM |
well i think i have got to admit defeat, i have been praying that it wasn't the clutch, but it looks like that is the case,
well one last comment, oh F**K!
omega0684
| posted on 20/5/07 at 10:10 PM |
raz, have you rang westfield about the diffuser?
DIY Si
| posted on 20/5/07 at 10:25 PM |
If you're lucky it may be the clutch needs adjusting, you may get away it. Not too likely, but you can always hope.
Sun Tzu, The Art of War
RazMan
| posted on 20/5/07 at 10:44 PM |
I'm giving them a call first thing tomorrow - that drawing you emailed me is almost exactly the same as my design - spooky
Raz
