ditchlewis
| posted on 21/5/07 at 07:36 AM |
Running very rich
Hi Guys
Got the car fired up yesterday and it was running rough. Whipped the plugs out and they were black and soot covered so the engine is running very very
rich.
I need to tune the carbs, is Colortune still the best way ?
Last question, what size are the plugs on the old Pinto, will I need and adaptor to suit the plugs as colortune only comes with a 14mm plug?
Ditch
flak monkey
| posted on 21/5/07 at 07:55 AM |
Pinto is std 14mm plugs.
Colourtune is one of the best home methods of tuning. Allows you to get pretty close.
Sera
http://www.motosera.com
ditchlewis
| posted on 21/5/07 at 08:18 AM |
many thanks i will go to halford at lunch time.
ive only had the car idleing for a few minutes and the plugs foul, i would hate to think what it would be running like after half an hour. i would be
getting to tha SVA coughing and spluttering
ditch
cadebytiger
| posted on 21/5/07 at 08:26 AM |
reading the book i have been using to set up my carbs (ie not an expert myself) it has a whole section on how the plug colour can only help ou fine
tune your engine if the engine is set up well and you know it like the back of your hand.
Will read again tonight and let you know exaclyt what is says
flange nut
| posted on 21/5/07 at 08:30 AM |
IIRC Flak Monkey is wrong, the plugs for a pinto are something like 18mm, although the the hexagon on the outside is the same as a standard plug
spanner.
Geoff
indykid
| posted on 21/5/07 at 09:30 AM |
spanner.
Geoff
it's an 18mm thread, a 19mm socket size, but a 14mm plug.
i'm gonna go out on a limb and say that's the diameter of the insulation.
either way, if you go to look for a plug socket, they're marked 10, 12 and 14mm.
pintos definitely have 14mm spark plugs
tom
| posted on 21/5/07 at 09:34 AM |
If I start my car and let it tick-over on the drive I find that the plugs can be very black. However, if I check them after a good run then
they're the right colour (for what that's worth).
You'll have some fun with the colortune - IIRC you've got twin Webbers, so you'll also have balancing to contend with! It does tell
you if you're in the right ball-park though.
ditchlewis
| posted on 21/5/07 at 12:08 PM |
indy kid has a point, the plug may be a 14mm but the socket is much larger. i've ordered the standard kit which comes with a 14mm plug, and i
notice that on some US web sites you can get larger and smaller plugs from colourtune.
David you are right i'm running twin 45 dellortos    which will also need balancing at the same time.    .
hope this will get it running a bit better
Ditch
paulf
| posted on 21/5/07 at 12:34 PM |
The pinto plugs have an m18x1.5mm thread, crossflows, zetecs, etc have 14x1.25mm thread which is what the standard colour tune is.
Have you ran the car on the road or just ticking over in the drive ? .I always found my crossflow sooted up the plugs if just started and allowed to
idle before i had it on the road, but was ok when driven normally. I once tried using a colour tune on my MGB but found i could get a better result
just by adjusting for best tickover by ear, all it allows is the idle mixture to be set up, so of no real gain for general driving in my opinion.
Paul.
Ditch
| posted on 21/5/07 at 06:51 PM |
spanner.
Geoff
tom
No all Pintos have 18mm Tapered seat plugs, the hexagon AF size is the same as old style 14mm gasket seal plugs.
Modern 14mm gasket seal and tapered seat plugs use a smaller size hexagon.
[Edited on 21/5/07 by britishtrident]
| posted on 21/5/07 at 07:01 PM |
If it is running that rich either the choke/cold start is stuck on or the float level is to high or the float chamber is flooding.
