24vseven
| posted on 21/5/07 at 09:10 PM |
x/flow flywheels
Hi heres one i realy should no the answer to but i dont so i thought i would throw it open to the colective knowledge on here
are there any diffrences in the ring gear on crossflow flywheels in relation to the type of starter used ie converting from a remote solinoid one to a
piggyback soliniod
i have a 5 speed type 9 box with all this too
so wich starter do i use pinto or crossflow
Confused but excited.
| posted on 21/5/07 at 10:13 PM |
There are two types of ring gear fitted to X-flows, depending whether the starter is pre-engaged or inertia type.
There was a thread on this within the last few days.
| posted on 22/5/07 at 08:12 AM |
This old thread covered this subject:
LINKY
If you look at the picture halfway down, you'll see a picture of the 2 types of ring gear. Inertia on the left, with chamfers to help the pinion
engage. Pre-engaged on the right.
You'll see that the ring gears are in different positions, and the pre-engaged one has more teeth.
In other words, if you want to swap the starter motor you'll have to change the ring gear. Last time I asked, the ring gear was around £30 -
£40, plus a small amount of labour charge at a machine shop (the gear is a shrink-fit on the rim of the flywheel). You can fit them yourself, but
I'm not sure it's worth the effort.
HTH,
24vseven
| posted on 22/5/07 at 11:40 AM |
i have boxes of flywheels kicking around just never payed any attentinon to wich was wich so needed to know what to lookfor cheers guys
