darrens
| posted on 22/5/07 at 08:38 PM |
RV8 Oil Pressure Sender
Anyone know the part No. for the Oil pressure sender, (not the low oil pressure switch) think they had them on the SD1's and Stags
After a 10-180 Ohm one if any can help (not rate please about the idea of paying the £25 from speedycables)
Agriv8
| posted on 22/5/07 at 10:15 PM |
they come in two flavours.
have a look on ere
rimmer v8 oil
regards
Agriv8
Paradoxia0
| posted on 22/5/07 at 10:45 PM |
Got my oil pressure sender from ETB Instuments but that is as I have the ETB oil
pressure gauge. (Bit more then £25 with the adapter though)
If you are after the oil pressure switch (which from your description I don't think you are) then
Europa do that switch which with one of the
ETB adapters works a treat!
BTW - the adapter I needed for my engine was the 1/2" UNF.
Mark
[Edited on 22/5/07 by Paradoxia0]
There is no replacement for displacement...
