Headrush
posted on 23/5/07 at 07:00 PM |
Heater matrix orientation ('Norway' heater unit)
Does anyone know which way up / round this heater unit goes?!?
The schematic cant be right as it'd never bleed and I cant figure out how it should be oriented!
Any ideas?!?
posted on 23/5/07 at 07:37 PM |
Opposite way up to the picture with the two pipes into the engine bay and the motor underneath I'd say.
Blackbird Rush
posted on 23/5/07 at 09:13 PM |
Jon,
This is pretty much the same unit i had in My V8 rush, rotate it round through 90 so the pipes are at the top right....
Ash.
Headrush
posted on 24/5/07 at 07:43 AM |
Cheers Ash -
I might flip the matrix and modify the housing so that the pipes come out top left as its much more in line with the rest of the plumbing. I guess
then I reverse the flow as marked on the diagram as the front and back of the matrix will be reversed.
(I've already bonded a mounting plate and stand-off spacers to the inside of the scuttle so its easy enough to mount)
J
BTW thanks for the boot cover - it'll finish it off really nicely!
Headrush
posted on 24/5/07 at 10:25 AM |
air locks
I can rotate the unit and flip the matrix so that the outlet is at the top left, but then the return pipe will have to go down to the expansion tank
hence creating an airlock - any ideas / suggestions how this can be avoided?!?
(Does anyone sell a 16mm or 5/8 pipe with a bleed screw in it like some manufacturers put on their hoses at air lock points?)
J
Blackbird Rush
posted on 24/5/07 at 09:07 PM |
Jon,
No Probs glad the cover went to a good home
My heater had the pipes at the top, exited through the scuttle then down to the engine, yes airlocks are a possability, but i never experianced
them.
You could always get a household copper pipe T-piece, 15mm with a smaller outlet, then attach a short hose with a blanking bit in the end (bolt &
hose clip worked for me) then you can bleed off the air if needed.
Ash.
