Author: Subject: de dion again
oadamo
posted on 24/5/07 at 07:48 PM Reply With Quote
de dion again
hi all its me again lol ive made jet another de dion but ive came to mount it on the bottom of the car and ita a no go. i dont have room for it. if i lower the car any more it will be sitting on top of it any idea what i can do as i need to go about 4-5in lower
adam
this is the height as it is and there is a inch gap from the boot floor and the top of the de dion axle so i cant go no lower
[Edited on 24/5/07 by oadamo]
flak monkey
posted on 24/5/07 at 07:51 PM Reply With Quote
What car are you trying to fit that under? Not a sierra surely?
Sera
http://www.motosera.com
worX
posted on 24/5/07 at 07:53 PM Reply With Quote
it's a saxo I think Dave...
Cut the floor!
flak monkey
posted on 24/5/07 at 07:57 PM Reply With Quote
Ah, that explains it
Yep, cut and shut the floor
Sera
DIY Si
posted on 24/5/07 at 07:58 PM Reply With Quote
The only way forward is to cut the floor out. Just move the floor up a few inches and job's good 'un! Since the car was never designed to have all that under the backend, you'll have to re-design it to make it all fit. It'd have to come up/out for the shockers anyway.
Sun Tzu, The Art of War
oadamo
posted on 24/5/07 at 08:03 PM Reply With Quote
six replys i only went to the shed lol.
ive made a frame for the floor for the diff
i think i might have to cut the floor out then and just make a subframe. i didnt want to cut the boot out but it looks like ive gotta adam
oadamo
posted on 24/5/07 at 08:15 PM Reply With Quote
any one no how much travel i need for the suspension
adam
Fatgadget
posted on 24/5/07 at 08:22 PM Reply With Quote
If it's a rally car,plenty.If it's a race car,not much.If its a road car somewhere in between.
worX
posted on 24/5/07 at 08:25 PM Reply With Quote
I suppose 4 inches of travel if it's going to be a fast road/track car!
to add to the above - if I were you - I would cut the entire rear floor away. Start with your suspension pickup points, then consider your structural requirements (where to mount suspension/diff etc) and then cover the whole lot in Aluminium.
That way you will have saved a load of weight aswell, and it wil be a damn sight easier to work on!!!
hth
[Edited on 24/5/07 by worX]
oadamo
posted on 24/5/07 at 08:29 PM Reply With Quote
i now thinking of just making a whole subframe the size of the boot. and then just cut the whole floor out and then just weld the frame in it would be a lot easer. then i can test it all of the car and get it all right adam
worX
posted on 24/5/07 at 08:30 PM Reply With Quote
LOL
oadamo
posted on 24/5/07 at 08:34 PM Reply With Quote
the Aluminium is a good idea aswell cus all the frame would be welded in it would just be for looks and to keep the noise out adam
posted on 25/5/07 at 06:38 AM Reply With Quote
Have a look at Bogg Bros and MK Engineering websites for examples of how Fiestas have been converted to RWD. Basically, cut the rear floor pan out, make a subframe that houses/locates the suspension points, diff carrier etc. This will give you a stiff structure to work from. Then fit removable interior panels for future access.
