shades
posted on 25/5/07 at 08:36 AM |
fuel hose question
I got a local company to adapt my fuel rail fittings on my 4age. They added tails which I can connect to the brass connectors using jubilee clips
onto the main copper lines. Trouble is I asked for 8mm ID, but when I get them home they have used 9.5mm ID. Question is, will the jubilee clip take
up the 1.5mm and make the connection without leaking fuel?
Adrian
RazMan
| posted on 25/5/07 at 08:49 AM |
I wouldn't use Jubilee clips on fuel lines - they tend to pinch the pipe if they are a bit loose to start with and might leak. Use proper fuel
pipe clips which are the correct size for the od of the pipe you are using.
Raz
| posted on 25/5/07 at 09:05 AM |
vwp for proper pipe clips.
Cousin Cleotis
| posted on 25/5/07 at 12:42 PM |
9.5mm hose on a 8mm pipe is no good. I would use 3/8" pipe, which is 9.5mm, or have the hoses made up with 8mm tails.
Paul
shades
| posted on 26/5/07 at 09:52 AM |
Thanks guys,
I have ordered some adaptors....
Adrian
