nitram38
posted on 25/5/07 at 09:27 AM |
R1 airbox
I have the R1 airbox with my 05 engine and to keep things simple I want to retain it on my car.
The engine will be in the normal orientation of a bike but at the rear of the car.
The airbox has a triangular opening to the filter underneath so I will need to duct it to try and take advantage of some of the ram air.
Does anyone have a picture of the standard duct for the front of the R1 to the airbox, before I set about making a custom duct?
posted on 25/5/07 at 10:25 AM |
Ram air will probably not affect the fuelling in a car as it doesn't really come into effect till you are into 3 figure mph. You will be better
off ducting cool air though.
nitram38
posted on 25/5/07 at 10:37 AM |
It has got to help with hp a bit by pressurizing the airbox. Afterall, that is what most racecars do.
I would just prefer it rather than just a simple duct.
Although it will be noisy I will have the opportunity to put the inlet right behind my left ear!
I will be wearing a crash helmet.
ChrisGamlin
posted on 25/5/07 at 03:34 PM |
Yep but as Pete says ram air of any sort (it doesnt matter which, it all uses the same air!) has very little effect below 90-100mph because the air
pressure increase simply isn't very much.
By all means plumb it in if you can, but I wouldnt compromise other aspects of the setup just so you have ram air in place.
posted on 25/5/07 at 03:39 PM |
Some numbers to back up the ineffectiveness of ram air at lower speeds:
http://forums.corvetteforum.com/showthread.php?t=1129295&highlight=ram+air&forum_id=1
mangogrooveworkshop
posted on 25/5/07 at 05:36 PM |
mangogrooveworkshop
posted on 25/5/07 at 05:40 PM |
nitram38
posted on 25/5/07 at 05:52 PM |
The airbox on my R1 has a triangular opening underneath and not a duct like that one.
