Bacon2002
| posted on 27/5/07 at 09:30 PM |
Clutch for Zetec & Type 9 gearbox
I am about to buy a 2.0l Zetec (black top) and a type 9 gearbox, the engine does not have a clutch, it comes from a Mondeo with 42k miles.
No doubt a dumb question but should I get a replacement clutch for a Mondeo 2.0l?
(A clutch being a pressure plate a friction plate and I assume a trust bearing.)
Many thanks,
UncleFista
| posted on 27/5/07 at 09:36 PM |
All the info you need is Here it even lists part numbers
HTH
Tony Bond / UncleFista
stevebubs
| posted on 27/5/07 at 10:25 PM |
Or just call Dunnell and get a replacement lightened 1.8 flywheel modified to take standard Pinto Clutch
Chippy
| posted on 27/5/07 at 11:09 PM |
[http://www.gibbs111.fsnet.co.uk/eng_gear_comb.htm[/url]
Try the above site very good, and informative. HTH Ray
spw1970
| posted on 28/5/07 at 09:04 AM |
Clutch
I had a xflow based Sylva Striker that was mated to a type 9 5 speed box. It used the clutch plate from a Sierra and the rest was Mk2 escort. I
EVENTUALLY found someone who would sell me just the plate that I needed rather than having to buy a complete clutch kit for a Sierra and throw most
of it away....
TangoMan
| posted on 28/5/07 at 09:57 AM |
Or Retro Ford in Corby, as they may (or may not) be cheaper. Mine was circa £50 IIRC.
Summer's here!!!!
