Author: Subject: help what engine
big daz2
posted on 28/5/07 at 09:57 AM Reply With Quote
help what engine
im a novice builder,iv just bought a locost space frame with nose cone and arches and escort mk2 doner parts,rear axle,brakes x flow 1300 and gearbox,my q is do i fit this engine because ive got all the v5 docs for this doner.but my plan when i started this was to fit a cosworth 2lt turbo engine but iv ben told there abit mad but i love rwd turbo cars.if i was to go for the cosworth option can i use any of the escort mk2 parts like rear axle wiring ect or do i just fit what ive got and get it through an sva.any advise welcome any other turbo motors to go for thanks daz
flak monkey
posted on 28/5/07 at 10:05 AM Reply With Quote
How much do you have to spend?
Cossie parts are very very expensive, if the engine needs work be prepared to spend a fortune on it.
If you want to use the live axle you will probably need an uprated diff and halfshafts to take the power. None of that stuff is cheap, or easy to come across.
If you want to use the cossie you would be better using a sierra rear end with a de dion as your chassis mounts wont need changing. You could then fit a 7.5" LSD to cope with the power/torque a bit better.
What do you want the car for. You will never be able to use the power of the cossie on the road, and if you want to run high boost, be careful in such a light car.
Have a look at Hicosts car in the photo archives, he has a cossie lump fitted.
Sera
http://www.motosera.com
ecosse
posted on 28/5/07 at 10:11 AM Reply With Quote
Hi Daz
If it was me I would use the bits you have and get it built and SVA'd, then look at going with the cossie unit.
But if you have plenty time and money doing it the way you want it straight off saves you rebuilding it at a later point.
Your choice
Alex
PS
And as said, cossie power in a seven is extreme unless you are aiming at a track missile
big daz2
posted on 28/5/07 at 10:17 AM Reply With Quote
thanks david moneys not a massive problem but i dont want the car costing more than 6k as that was m buget to buy one but i bought the frame and doner parts for 400 quid so theres a theme to keep it cheap i plan on using it for weekend road use track days and quarter mile thats why i wanted a turbo can you sugest any other sva freindly options.
NS Dev
posted on 28/5/07 at 10:21 AM Reply With Quote
I think we will all get on out individual horses here, but for me, the Vauxhall XE 16v is hard to beat if you can find a good one.
I have just paid £200 for a complete, driving car with a good one in, then broken the car and made more than £200 selling the bits I didn't need, so the engine actually cost me less than £0.
With throttle bodies and a decent manifold on the otherwise stock engine it makes just over 200hp and around 165lb ft of torque, without the weight and driveability issues of the turbo.
Pushes my locost 0-60 in under 4 secs (getting the datron on it in the next few weeks to check properly! )
graememk
posted on 28/5/07 at 10:26 AM Reply With Quote
i run a nissan 1.8turbo and its very hard getting the power down on the road
you would pick up a nissan s14 for a few ££ and a very easy 300bhp thre
flak monkey
posted on 28/5/07 at 10:36 AM Reply With Quote
I would go with Nat on this one. If you want quick, and modern engine, go XE not Zetec.
If you want simple old school engineering, go with the pinto. Silly cheap to tune, loads of knowledge and parts available.
Or you could fit a 5 pot duratec from the new focus ST, they have plenty of oomph.
If you want to keep it under £6K I would avoid the cossie, but if you can find the parts cheap you should be able to do it.
SVA it doesnt matter much as long as you get the V5 changed to have the engine number on you are going to use in your car. You'll still get an age related plate. Just bear in mind you want a pre-95 engine to avoid the Cat test though.
Sera
NS Dev
posted on 28/5/07 at 11:05 AM Reply With Quote
Originally posted by CaLviNx
Hi
If i didnt know any better i would agree with "NS Dev" As i had a XE engine in my kit car,but after driving my GSXR1000 engined car for a good bit recently, I will NEVER ever go back to a car engined 7 again.
after a "spirited" drive yesterday, I managed to prove to a staunch car engined driver that bike engines do have a bit of torque for overtaking in the higher gears, and can run along nicely @ 60, and don't need the nuts revved off them at every opportunity, to such a point he admitted he would quite like a bike engined car..........
But only you can decide which engine you can live with as NS-Dev says everyone will sit on their own horse, and only you can decide which type of horse (or horse power) suits you, I would say try and get a run in a few cars with differing engines.
It would be a shame to make a choice, fit that engine then find out once your driving it that you don't really like it......
good luck with whatever you decide to run with.
[Edited on 28/5/07 by CaLviNx]
Did you ever drive yours with the XE in though?
not questioning in a cheeky fashion, just inquisitive.
I have been in a number of bike engine cars, including a radical SR3 with powertec 1500 busa in it with 240hp, and I have to say I am still REALLY happy with the vauxhall engine.
I will say now that I am not a particularly steady driver!!! and am more than capable of controlling a car at speed, but I find that I can quickly run out of reaction time on any stretch of road where I can keep on full throttle for more than 8 secs or so (i.e. substantially over 100mph) from a standing start.
I understand the plusses of the bike engine, but in SOME situations, and SOME cars, the plusses seem to only be there to cover the minuses, i.e. several times I see that the plus of the sequential box is mentioned, but then it really is necessary because you need to change up so quickly as you have to make more changes.
Its a long debate with no answer, but I was worried that on going out in BEC's, particularly the radical, I would regret using the vauxhall engine, but having spannered on and been out in the radical most of last year, I'm glad I have the vauxhall!!!
The bigger bike engines certainly have reasonable torque, a std hayabusa is ok, the 1500 cc version is much more acceptable.
This year we are racing a caterham superlight cosworth, and have abandoned bike engines.............and have no spare engine with us, be interesting to see if we need one!!
We'll see what happens, it certainly can't be any MORE expensive!
NS Dev
posted on 28/5/07 at 11:12 AM Reply With Quote
As Flak says, a pinto is also silly cheap to tune, and whilst even when tuned it won't be the match of an XE etc, for some one that has not worked on an engine before, it is a great learning point.
I remember building my first pinto (1996, eek!!) and it was old hat then, but it forgave my clumsy gasket scraping, it didn't instantly melt when I ran it a bit lean, it responded to my early porting efforts and it NEVER broke down enough to actually stop the car driving. It took us all round scotland at some considerable rate (including a very memorable if slightly hairy run at night up the side of loch lomond!!!!!!)
Most (not all! ) engines have their benefits, and if you follow the advice of the majority on here you won't go far wrong (i.e. crossflow, pinto, XE, zetec, bike engine, they're all good in their own way)
graememk
posted on 28/5/07 at 11:18 AM Reply With Quote
also it dosnt matter what engine you put in, its going to be fast as theres no weight
a 1.3 xflow isnt slow in a 7.
Volvorsport
posted on 28/5/07 at 02:18 PM Reply With Quote
dont fit a focus St 5 pot theyre made of chocolate , use a volvo engine .
a 2.5 will be 170 bhp as std NA, with plenty of headroom for more - im doing the initial groundwork at the moment .
www.dbsmotorsport.co.uk
getting dirty under a bus
Dale Jarret
posted on 28/5/07 at 03:32 PM Reply With Quote
Hi All
If you are building a Book Locost, which I assume you are, as you are using Escort MK2 bits, then, you are going to have fitting issues, for a Pinto and a lot of the other taller engines, without having to go through the bother of chopping sumps etc, and bonnets.
Also bear in mind with a 'Book Locost' there are bell housing clearance issues and gear box restrictions.
The Locost, is dimensionally much smaller than the 'Indy' size car.......
Just food for thought......
D.J.
NS Dev
posted on 28/5/07 at 04:32 PM Reply With Quote
Mine is a book locost and the vauxhall XE 16v fits under the std book bonnet line................................just!!
Point to bear in mind though, as the MK's etc are a lot bigger
[Edited on 28/5/07 by NS Dev]
Mark Allanson
posted on 28/5/07 at 05:23 PM Reply With Quote
I thought the ST 5 pot was a Volvo engine?
Volvorsport
posted on 28/5/07 at 05:29 PM Reply With Quote
It is , but theyre made cheaper or something , lots more plastic stuff than the volvo engine .
they also have a integral exhaust/turbo housing .
much better to get a 2.3 volvo engine , they are much more reliable at higher boost pressure . the eng/trans is more suited to a rear engine car tho .
its a wonderful noise !!!
flak monkey
posted on 28/5/07 at 05:33 PM Reply With Quote
Looks like a separate turbo to me. Sorry pinched the pic from Danozeman: Rescued attachment turbo duratec2.jpg
Sera
Volvorsport
posted on 28/5/07 at 06:06 PM Reply With Quote
turbine housing is integral to the exhaust manifold .
the center cartridge obviously comes out !!!
big daz2
posted on 28/5/07 at 08:18 PM Reply With Quote
thank lads it makes great reading,i dont think im any clearer on what to do but i think the logical thing to do is fit what iv got,compared to the cars iv had i just asumed that 1300 was going to be very slow.are the any mods that i could do with the 1300 to make it bigger brake.its a very good point that ive only ever sat in a 7 never driven one.i sold my subaru type r to buy this so i didnt want anything slow but i also dont want the runing costs of a realy hi pec car again as its only a second car.i like the sound of the nissan 1800 turbo.how difficault is it to fit a bike engine later if i just get the car through an sva.sorry for all the q im very excited at the mo thanks all.
TangoMan
posted on 28/5/07 at 08:56 PM Reply With Quote
Don't be put of the Zetec. I have just got my 2.0 back on the road today after sorting the head and fitting a pair of cams.
In standard form with TB's it was much quicker than my tuned Pinto but now it feels even better. The problem now is getting the power down onto the road. It was interesting in the wet
Not sure about the clearance issues in a book chassis though. Taller than a Xflow but shorter than a Pinto.
TBH anything giving >150bhp will be quick so go with what you feel will suit you.
Summer's here!!!!
posted on 28/5/07 at 09:24 PM Reply With Quote
If you keep the 1300xflow and build the rest of the car to spec you could run it in the 750mc Locost race series
The easiest power mod for the 1300xflow is to replace it with a 1600/1700 xflow!
big daz2
posted on 28/5/07 at 09:28 PM Reply With Quote
should i just get it re bored
