Author: Subject: Zetec 2.0l Flywheel
Bacon2002
posted on 28/5/07 at 01:15 PM Reply With Quote
Zetec 2.0l Flywheel
Am I correct in assuming I will need a flywheel puller to remove the flywheel from a 2.0l Zetec (black top).
If so is there any particular one I should look to get?
Also does anyone know where I can get a 1.6 or 1.8 Zetec flywheel?
Many thanks,
David.
jambojeef
posted on 28/5/07 at 01:35 PM Reply With Quote
I have 1.8 flywheel for you!
Where are you?
Geoff
Bacon2002
posted on 28/5/07 at 01:44 PM Reply With Quote
Geoff,
Thanks for the reply, I'm in Rayleigh, Essex.
Are you in Newcastle?
ch1ll1
posted on 28/5/07 at 01:58 PM Reply With Quote
hi undo all the bolts and the flywheel should fall off!
if not give it a tap with a knocking stick and i will drop off
jambojeef
posted on 28/5/07 at 02:24 PM Reply With Quote
Hi, I am indeed...
However....there may be ways and means of getting it to cheaply!
I run up and down the A1 to bedfordshire every now and then and could drop it off in Bedford if thats any good?
Failing that parceline or some guys like that do it cheaper than royal mail iirc....
Geoff
Bacon2002
posted on 28/5/07 at 02:58 PM Reply With Quote
Geoff,
I will look into how much Parcel force want, I'm pretty sure they collect as well. Do you know approx how much the flywheel weighs?
How much are you look for it and any chance you have a cranckshaft sensor/sensor housing?
Basically my Zetec engine came our of an automatic and therefore I understand I need to use a crankshaft sensor/sensor housing from a manual Zetec.
I have seen a 1.6 flywheel on eBay which is local to me and I've put a bid on it, so if I have no joy with that I'll let you know.
Thanks again,
jambojeef
posted on 28/5/07 at 03:03 PM Reply With Quote
Yep,
I also have the crank sensor.
If you want - you can have the flywheel, clutch, cover and sensor for £15.
Let me know if thats any good?!
Geoff
Bacon2002
posted on 28/5/07 at 03:52 PM Reply With Quote
Geoff,
You have deal, I just need to work out how to get it picked up and how to pay you.
Can you let me know, the appox weight, when your going to be about for someone to collect it (probably parcel force). Also I'll need to get your address.
I have not used the U2U thing before but I suspect that may be the answer for sorting out the details.
Will you be OK to wrap it all up?
I will try to U2U you and we can sort out PayPal or whatever you prefer.
Many thanks,
