oadamo
| posted on 29/5/07 at 04:26 PM |
zetec turbo gasket
hi can anyone tell me when you turbo a zetec and you use a decompression plate and 2 head gaskets. how do you go about doing the timing. because i
think if even if you have adjustable pulleys wont the timing stil be out because you have extended the block adam
NS Dev
| posted on 29/5/07 at 04:28 PM |
Not if you have adjustable pulleys, otherwise yes it will.
You can adjust it to exactly where you need it with adjustable jobbies though.
(obviously ignoring the standard numbers and setting it by lift on overlap, and doing power runs to confirm)
oadamo
| posted on 29/5/07 at 04:31 PM |
turbo it is then lol. the company that does some work for use said they will do me a decompression plate very cheap. and they can scan the gasket ive
got
adam
NS Dev
| posted on 29/5/07 at 04:36 PM |
don't forget to do the plate in either copper or ally, they are a bit more forgiving on the gaskets!
ecosse
| posted on 29/5/07 at 04:39 PM |
If you got the plate made out of copper the same thickness as your gasket and decomp plate it should be possible to then do without the traditional
gaskets should it not?
Alex
the_fbi
| posted on 29/5/07 at 07:37 PM |
Alex
Exactly, as per
http://www.pumaspeed.co.uk/showdetails.php?id=470
oadamo
| posted on 29/5/07 at 08:08 PM |
the spacer plates gonna cost me £10 plus the two gaskets. ill try that first then if it doesnt work ill buy some forged pistons. the engine wont last
long anyway
adam
| posted on 29/5/07 at 08:12 PM |
The cam pulleys on a Zetec are not keyed to the cams like the old Pinto engines, lf you follow the cam timing procedure as long as the belt is long
enough the valve timing would be exactly the same
