Michael
| posted on 29/5/07 at 09:23 PM |
Radiator
Im using the MK2 Escort Crossflow Engine, and currently have the radiator mounted, but now realise the filler is lower then the thermostat housing.
What rads have others used and i think i have seen some with rad caps in the thermostat housing, where are these from?
UncleFista
| posted on 29/5/07 at 09:45 PM |
Our rad was lower than our thermostat housing, we just filled by unscrewing the temp sensor (we used a Fiesta MK3 thermostat housing) from the housing
and filling from there, it's fine.
The housing I "think" you mean, with the cap, is from the x-flow engined XR2, but are available from
Burton Power Part No: FP610M
[Edited on 29/5/07 by UncleFista]
Tony Bond / UncleFista
jamesbond007ltk
| posted on 29/5/07 at 09:46 PM |
If you look on page 91 of Ron's 2nd edition you'll see the solution. Its a Fiesta (Mk2?) thermostat housing with fanswitch on it. This can
apparently be unscrewed to act as a filler.
Dont quote me on this. i am just quoting the book.
HTH
Rich
(Yup, temp sender not fanswitch!)
[Edited on 29/5/07 by jamesbond007ltk]
Michael
| posted on 30/5/07 at 09:39 PM |
I have a MK2 fiesta thermostat housing and switch, but when the cap releases pressure how will the system self top up? If i fit an expansion bottle
as the cap must be designed to let water out but not back in?
UncleFista
| posted on 30/5/07 at 10:24 PM |
The cap shouldn't have any pressure to release, it should only release pressure when it boils (mine did regularly until I'd found the
dodgy wire to the electric fan) if your cooling system is doing it's job, it should be more or less sealed, just as it was in the Escort. My car
didn't have an expansion tank and didn't lose coolant, it never needed more than a drop when I checked it...
Michael
| posted on 7/6/07 at 09:02 PM |
What engine size and age of Polo is it best getting a rad from or what otehr types of radiators have others used?
| posted on 8/6/07 at 04:58 PM |
Fit a header tank on the bulkhead for filling , fit a blanking cap to the rad or get the rad filler removed and soldered up .My thermostat housing has
a fan switch in it although it isn't used as the wires foul the underside of the bonnet, it also has a bleed off pipe that is connected to the
header tank so that system "bleeds" itself with no problems.
