Author: Subject: Type 3 gearbox
Alan M
posted on 30/5/07 at 08:05 AM Reply With Quote
Type 3 gearbox
I've just got hold of a type 3 gear box for my crossflow Locost. Has anyone got a spare sliding joint for the propshaft, or maybe even a complete prop?
Alan M
posted on 30/5/07 at 08:36 AM Reply With Quote
Failing anybody having one. Does anyone know what donor vehicles I should be looking for?
DavidM
posted on 30/5/07 at 08:38 AM Reply With Quote
Which gearbox is the type 3? 4 speed, 5 speed, got a picture?
Alan M
posted on 30/5/07 at 08:44 AM Reply With Quote
It's a 4 speed, about 3 inches longer than the standard escort box. It was fitted to early Sierras and mark 3 Capris but I think they used a rubber doughnut to connect the prop, which is no good for a Locost
Alan M
posted on 30/5/07 at 08:51 AM Reply With Quote
Type 3 Gearbox
picture attached
flak monkey
posted on 30/5/07 at 08:53 AM Reply With Quote
If you have a word with someone like Bailey Morris, they will make you a prop to your specification.
You really do need a professionally made and balanced prop. You dont want it breaking...
Sera
http://www.motosera.com
Hammerhead
posted on 30/5/07 at 09:22 AM Reply With Quote
I've got a caterham prop for sale. Its too short for my type 9 but if youe type 3 is longer it might fit. It bolts onto the diff and slides into the gearbox.
stevec
posted on 30/5/07 at 09:52 AM Reply With Quote
If you are anywhere near Coventry try Dave Mac propshafts Northey Road Coventry, 02476 683239 Ask for John. Very helpful and will make any propshaft. Or steering shaft.
Steve.
MAP
[Edited on 30/5/07 by stevec]
Alan M
posted on 30/5/07 at 10:01 AM Reply With Quote
Type 3 gearbox
I'm going to Coventry this p.m. so I'll call on them. I've used them before for driveshafts & they are good but I didn't know if they could get sliding joints
DavidM
posted on 30/5/07 at 11:29 AM Reply With Quote
Ah one of those. Each to there own but it seems to me you're adding a lot of weight when compared with a type 2 4 speed with no real advantage. Have you considered a type 9 5 speed.
I converted mine over the winter from type 2 to type 9 and it's transformed the car. Well worth the weight penalty and much more civilised on a run.
Alan M
posted on 30/5/07 at 01:37 PM Reply With Quote
Just discovered that the gearbox won't come out on its own (engine too), so maybe I'll continue with the old 4 speed until after it's on the road. I'd read that the type 3 box was stronger (hence the extra weight but really it was just to save bending the lever
