HAL 1
| posted on 31/5/07 at 08:02 PM |
dizzy question
Hi
just changed my dizzy back to points/condensor due to problems with ecu, engine is 1985 2ltr pinto but dizzy age unknown but also from pinto, seems to
be ok but anyone know of any likely problems ?
Will probably get aftermarket set up when funds allow, any recommendations ?
All advice welcome
UncleFista
| posted on 31/5/07 at 08:07 PM |
quote: Originally posted by HAL 1
<snip>
All advice welcome
RayWard has a megajolt for sale on this very forum
HERE
For £90 I'd snatch his hand off. If I didn't have one already
Tony Bond / UncleFista
pajsh
| posted on 31/5/07 at 09:05 PM |
Couldn't agree more.
Easy peasy lemon squeezy and well cheap for what you get.
If I can get it right first time it must be simple.
I used to be apathetic but now I just don't care.
DarrenW
| posted on 1/6/07 at 08:51 AM |
Defo go for MJLJ. Thats what i did and so far its great. Also tuneable for future upgrades and can be used on different engines should you so
desire.
The toothed wheel and sensor can take some sussing out but when you do you wonder what the fuss was about. After that you can run 2D mode until you
get to grips with MAP or TPS for the third D. Even 2D is better than std dizzy.
Only other challenge could be comms to the laptop but the new MJLJ software has that covered as well. Older versions liked serial port connection, new
one can take USB as well.
[Edited on 1/6/07 by DarrenW]
