Author: Subject: Leaky Fuel Tank
westf27
posted on 1/6/07 at 11:45 AM Reply With Quote
Leaky Fuel Tank
Need some sealer to repair leaky fuel sender in a steel tank on Lotus Seven.Whats recommended and not affected by fuel.
Yours Hopefully.....
craig1410
posted on 1/6/07 at 11:57 AM Reply With Quote
POR-15 Fuel Tank Sealer seems to generally get a good review but I've not used it myself. You can get it from Frost.
HTH,
Craig.
flak monkey
posted on 1/6/07 at 11:58 AM Reply With Quote
JB weld works really well And you can put it on from the outside. The por-15 stuff you need to put on the inside, which means its a tank out job.
Sera
http://www.motosera.com
craig1410
posted on 1/6/07 at 12:05 PM Reply With Quote
Also, I've had good experience with Plastic Padding Leak-Fix which sets much more quickly than JB Weld. I used Leak-Fix on my old Rover 800 which developed a seriously leaky tank.
posted on 1/6/07 at 12:14 PM Reply With Quote
The fuel sender will be either fom the Triumph Herald or Mini Van parts bins.
Else try Petro Patch -- quite effective shellac based
http://granvilleoil.com/subcatlist2.asp?fld_category=Maintenance%20Products
[Edited on 1/6/07 by britishtrident]
westcost1
posted on 1/6/07 at 02:19 PM Reply With Quote
Hi not related to the fuel tank question but
i saw your car driving down swan lane in sandherst a few months ago as i was riding my bike to a friends house lovely car and a super paint job really made my day.
craig1410
posted on 1/6/07 at 04:27 PM Reply With Quote
I don't mean to heckle but I had a bad experience with what I think was Petro-Patch when I had the leak on my Rover 800 with 68 litres of fuel in it...
I got it from Halfords and it came in a two part putty which you mix together by hand and then apply. It doesn't stick worth a damn and just made an even bigger hole in the tank. What started as a drip turned into a gush and I had to drain the tank into various containers which we found around the house. Quite a scary evening with 68 litres of fuel lying around!
Craig.
posted on 1/6/07 at 06:49 PM Reply With Quote
Petro patch
I used it years ago to seal a tank temporarily while I looked for another. It was a red liquid like paint which was applied with a brush and could be used with a backing to block bigger holes. It worked for me for the few weeks I needed it. I also found Red Foliac worked as well for a jointing compound as long as you don't want it to come apart again too easily.
posted on 1/6/07 at 08:00 PM Reply With Quote
Used Petropatch years ago on a Maxi tank, lasted for at least 3 years. It wasn't two pack type stuff as mentioned by Craig,
craig1410
posted on 1/6/07 at 08:27 PM Reply With Quote
Just checked, there is PetroPatch AND PetroPatch Putty. It was the putty which left me with petrol running up my sleeve. In fact I think I have used the other PetroPatch stuff as well years ago on an old Montego Estate which had a leaky tank near the inlet. I think it worked okay at the time.
Good luck,
Craig.
[Edited on 1/6/2007 by craig1410]
