cadebytiger
| posted on 4/6/07 at 04:09 PM |
Polo Rad
Anyone know what size the inlet/outlet pipes are on the polo rad.
I am thinking of changing to this but don't want t have to buy new hoses as i just got silicon ones!
Rupert
flak monkey
| posted on 4/6/07 at 04:10 PM |
32mm IIRC
Sera
http://www.motosera.com
cadebytiger
| posted on 4/6/07 at 04:11 PM |
sweet same as mine. i know they are in different places but it's a start
cadebytiger
| posted on 4/6/07 at 04:13 PM |
do you use a polo fan also?
Rupert
flak monkey
| posted on 4/6/07 at 04:15 PM |
I used a 10" spal fan off ebay. Pulls the temp down very quick.
Look in the horsebox section on ebay as they are used as ventilation fans on themm tend to go cheaper in there if you are looking for one.
Sera
cadebytiger
| posted on 4/6/07 at 04:29 PM |
brilliant.
not sure what i have at the moment.
It is quite small and sits behind the rad. Will have a closer look
omega 24 v6
| posted on 4/6/07 at 04:39 PM |
I concur 32mm and I used the fan from a fiat uno. Only prob is it's a puller not a pusher (i've reversed wiring but have'nt run it
on the car yet so don't know how reliable/longlasting etc it'll be in reverse,
SixedUp
| posted on 4/6/07 at 05:32 PM |
They're definitely 32mm in and out, with an additional small (5mm?) connector at the top which I teed into the expansion/overflow.
I used a "budget fan" from Stafford Vehicle Components (£30ish) which works beautifully with the polo rad.
Richard
marshall
| posted on 4/6/07 at 07:36 PM |
i used a polo rad with a RH fan £16 from e-bay and all works fine...
chris taylor
| posted on 4/6/07 at 08:22 PM |
Hoses
Anyone know what top and bottom hoses you use for connecting the polo rad to a 20. pinto ??
flak monkey
| posted on 4/6/07 at 08:29 PM |
For the top hose i used 2 45deg bends chopped out of a hose i had laying about joined with a bit of galvanised pipe
For the bottom hose I used a tight 90deg bend at the rad, just went into the motorfactors and had a rummage. At the block I used a weird shaped hose,
which reduced from the 38mm pump to 32mm and took the hose down below the aux belt. Then joined with another bit of galvanised pipe. I can find out
the QH number for the hose when I get home.
Sera
