caber
| posted on 5/6/07 at 10:16 PM |
Pinto heads
I have just aquired a 2.0 carb pinto head that I am going to put on my 1600. i have been told that these have better flow and bigger valves. Is this
correct and am I likely to get more power from my 1600 if I go this route with webber 40s or bike carbs?
TIA
caber
andyharding
| posted on 5/6/07 at 10:50 PM |
Assuming you have the normal 1.6 not the ong stroke then I think you'll do a great job of increasing the combustion chamber volume and lowering
the compression ratio. Bye bye power.
jollygreengiant
| posted on 6/6/07 at 01:51 AM |
The heads that you want are 1.6GT heads.
1.6 compression ratio but with 2.0 valves & camshaft.
OR
If you want to be silly get a 1.3 head and modify it to take the 2.0 cam and valves, this would take you compression ratio up to about 11:1 .
caber
| posted on 6/6/07 at 06:44 AM |
How much can I skim the 2litre head to reduce the combusion chamber volume?
TIA
Caber
PeterW
| posted on 6/6/07 at 03:22 PM |
Why not use it to lower the compression then stick a supercharger on it....
You know you want to....
Pete
mcerd1
| posted on 6/6/07 at 06:26 PM |
just seen this on ebay
http://cgi.ebay.co.uk/Ford-Pinto-Heads-1-6_W0QQitemZ280118704541QQihZ018QQcategoryZ27377QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
maybe someone here can work out what it is form the casting marks & photo's
[Edited on 6/6/07 by mcerd1]
