Author: Subject: engine mounts
oadamo
posted on 7/6/07 at 06:48 PM Reply With Quote
engine mounts
hi all
most of you no iam building a saxo track car. so hes my engine mounts for my zetec block
there 10mm x60mm flat with 40x40x3mm box. the rails are 25x25x3mm box. i no i need more bracing on the 25x25 for the frame but do you think it will be ok
thanks adam
oadamo
posted on 7/6/07 at 06:51 PM Reply With Quote
heres a quick pic of the front tunnel ive not got a lot to do now then i can give it some s**t. pmsl
it going better then i thought it would lol
TGR-ECOSSE
posted on 7/6/07 at 07:48 PM Reply With Quote
Looks more than strong enough. Some day i will post pics of the rwd fiat twin cam powered saxo that we built as a stock car
[Edited on 7/6/07 by TGR-ECOSSE]
worX
posted on 7/6/07 at 10:34 PM Reply With Quote
how much of the tunnel did you cut out Adam?
have you got a pic of it before you covered it in Ali?
oadamo
posted on 7/6/07 at 10:51 PM Reply With Quote
its covered in sheet steel 1.5mm now the tunnel is 150-170H by 200 wide iam keeping it as big as possible so if i have to go to a stronger box it should fit.should lol i think.ive got the car on 4 axle stands on the 4 points and ive only cut the front bit out yet. iam gonna weld it all up then cut the back bit out to try and stop anything moving.
adam
[Edited on 7/6/07 by oadamo]
