Author: Subject: HONDA CBR1000- 92 CARBS
oadamo
posted on 7/6/07 at 09:52 PM Reply With Quote
do you think these will be any good on a 2L zetec.
can you run a turbo setup without modding them
thanks adam
jambojeef
posted on 7/6/07 at 10:33 PM Reply With Quote
If I were you, Id consider megasquirting it on gsxr throttle bodies.
The CBR carbs will work for low boost but you'll have to buy a turbo fuel pressure regulator, fab up some sort of inlet manifold and then megaspark it anyway.
For a relatively small further outlay for the GSXR tb's and megasquirt you can make the most of the turbo and control your engine much more precisely.
My CBR turbo is only on its carbs as a stop-gap.
This winter it will get 'squirted as above.
Geoff
