Author: Subject: R1 Oil pressure sensor/gauge ?
Kosmo
posted on 10/6/07 at 09:02 PM Reply With Quote
I want to use an oil pressure gauge (electric) on my R1 5VY engine, anyone currently doing this and if so where do you fit the sensor on the engine ?
Kosmo.
nitram38
posted on 10/6/07 at 09:54 PM Reply With Quote
Do a search!!!!
But if you can't be bothered, there are 2 options.
Drill and tap the oil cooler bolt or remove one of the main gallery allen bolts that runs across the bottom of the block. Replace it with a drilled hex head bolt.
It is the same point that yamaha use to take pressure readings.
