rusty
| posted on 13/6/07 at 06:19 PM |
Type 9 oil
What oil is best for a standard Type 9, nothing to silly.
jos
| posted on 13/6/07 at 06:23 PM |
75w90
rusty
| posted on 13/6/07 at 06:27 PM |
Forgot to ask how much it will need for an empty box.
Catpuss
| posted on 13/6/07 at 06:34 PM |
Something like 1.9 liters? Halfords do 1 liter bottles. I just got two on trade card and they wern't too bad a price.
SeaBass
| posted on 13/6/07 at 06:41 PM |
https://www.burtonpower.com/default.aspx?/technical/tt_type9.html
Fatgadget
| posted on 13/6/07 at 07:11 PM |
We used to use ATF in ZF and rocket boxes with no issues.
Dusty
| posted on 13/6/07 at 10:51 PM |
I use ATF in mine for a slightly better change especially from cold.
Macbeast
| posted on 14/6/07 at 04:38 AM |
When I drained my box, the oil was pink. The guy who checked the box for me said yes that was right but he couldn't remember what it was called.
Would that have been ATF - I understand Automatic Transmission Fluid ?
rusty
| posted on 14/6/07 at 07:51 PM |
So is it ok to use AFT as I think I have some, is it better than Halford standard 75w90
| posted on 14/6/07 at 11:03 PM |
From the Retro Car Type9 guide:
BGH recommend Ford Semi-synthetic oil ESD M2C174-A Sepcification (Ford part A83SX 2c 175-AA), or Comma Semi synthetic gear oil.
They do not recommend engine oil, ATF or EP80.
| posted on 15/6/07 at 12:29 PM |
When I spoke to Brian from BGH at Stoneleigh he recommended the Comma oil. DO NOT use incorrect oil as it causes problems
BKLOCO
| posted on 15/6/07 at 12:37 PM |
100% agreement with above DO NOT use ATF
Semi snyth is best if box is in good cond.
I have heard of people using thicker mineral oils in worn boxes but it's likely to be a very short term solution.
snippy
| posted on 30/6/08 at 09:06 PM |
Type 9 - the fluid debate......
Just found this thread and I`m now confused. I am suffering problems getting 1st & 2nd gears when gearbox is cold or hot. It takes a bit of
persuasion to select. Spoke to a couple of gearbox reconditioning companies today who both told me to use Devron 2 ATF fluid in the box as standard
gearbox oil is no good. I have had 75w/90 in it as suggested in the Sierra Haynes manual. They say to drain this out and replace with Devron yet
others on here say otherwise?
Anybody want to throw any expert advice into the pot?
Nick
omega 24 v6
| posted on 30/6/08 at 09:17 PM |
I've used ep 75 90 GL4 and I DID NOT use halfrauds.
They wantes £7 ish a litre for their own brand. I also needed axle oil so for 4 litres I'd have been £28
I used a local shop (JRD in ellon for you local lads) who were selling the comma stuff for £2.99/ltr.
A saving of £16
sebastiaan
| posted on 1/7/08 at 08:55 AM |
I'm also using ATF in my 30 quid type 9 box. It's coupled to an EFI pinto and has done around 3K miles without problems. The gearchange is
superb using ATF, although i have not ever used the "proper" oil to begin with.
So if you do use ATF, it won't destroy the box within the first few miles.....
| posted on 2/7/08 at 10:33 AM |
Do not use an EP (extreme presuure sometimes called "hypoid" gear oil oil for complete fill --- use a gear oil without EP
additive.
A good multigrade semi-synthetic or full synthetic GL4 gear oil is ideal. -- Castrol Syntrax Universal 75w-90
EP oils are only for RWD drive cars with hypoid final drives and have shed loads of EP additive --- not a good thing in a synchromes gearbox.
MTX type oils for transnverse gearboxes have EP additive but not as much as Hypoid EP oils.
ATF is really a thin gear oil with similar ammounts of EP additive to MTX oils and anti foaming agents and friction additive (shulphur).
[Edited on 2/7/08 by britishtrident]
| posted on 2/7/08 at 10:37 AM |
A saving of £16
The final drive requires a full EP (Hypoid) GL5 oil such as Castrol Castrol EPX80w-90 gear oil
omega 24 v6
| posted on 2/7/08 at 08:35 PM |
Yep I bought 2 litres of gl4 and 2 litres of gl5 (should have siad that really)
