Author: Subject: 1.6 xr3i on carbs, advice needed please
thesnake505
posted on 14/6/07 at 03:21 PM Reply With Quote
hay all, im wondering if its worth putting bike carbs on a 1.6 cvh out of an xr3i? if it is what gains would i see, what ignition system would be the best to use? is it ok to use the head i have? what dissy do i use? cheers, your local friendly snake
posted on 14/6/07 at 03:36 PM Reply With Quote
Simplest ignition system to use is an Xr3 Carb dizzie.
mark chandler
posted on 14/6/07 at 05:56 PM Reply With Quote
People used to bin the EFI for webers years ago to increase power so it should be fine as is.
jacko
posted on 14/6/07 at 07:15 PM Reply With Quote
Hi i have bike carbs fitted and i get approx 30 - 35bhp over the std carb
ignition you could use a megajolt and dump the dizzy
I would think the head you have will be OK to use
Jacko
will121
posted on 15/6/07 at 07:25 AM Reply With Quote
cvh carbs
Im in the process of doing the same on a 1600 lean burn CVH with ported head, gone for the standard cvh distributor with the vacuum advance which is simply wired to a coil with no electronics! got zx6 carbs which are 38mm bore which should be just fine. only problem with these carbs is they need to be mounted at approx 45 degrees to keep the float bowl level. some less modern carbs can be mounted near level which would make the inlet manifold straighter. hope to have it all up and running in the next week!
