Poll: OT/ Excessive vibration [View Results]
a.) Replace the engine mounts?
b.) Adjust the idle speed (dissapears gradually until non-existant at approx 1400rpm)?
c.) Something else?
Author: Subject: OT/ Excessive vibration
arrybradbury
posted on 15/6/07 at 03:03 PM Reply With Quote
I'm currently getting a nasty vibration at tick-over in my vw polo (6N) which dissapears when i press the accelerator. Do I......:
Aico
posted on 15/6/07 at 03:56 PM Reply With Quote
Probably something is loose. Tightening a bolt or nut should do it. Just go and find it.
MkIndy7
posted on 15/6/07 at 03:58 PM Reply With Quote
HT lead?
Running lumpy like its on 3Cyls and then when you rev it up the spark jumps the gap and it runs smoother
James
posted on 15/6/07 at 04:01 PM Reply With Quote
Are you saying it idles at above 1400rpm?
Should be about 900rpm shouldn't it?
James
arrybradbury
posted on 15/6/07 at 04:44 PM Reply With Quote
Idles at about 900rpm, dissapears completely at 1400rpm and gets better progressively between the two.....
UncleFista
posted on 15/6/07 at 05:17 PM Reply With Quote
D. Ignore it 'til something falls off
Tony Bond / UncleFista
oadamo
posted on 15/6/07 at 07:49 PM Reply With Quote
pmsl
adam
Mark Allanson
posted on 15/6/07 at 08:46 PM Reply With Quote
If its the 1.4 75bhp TC, remove the carbon ridge inside the throttle body with carb cleaner, this will probably cure the overrun stall you have been experiencing
arrybradbury
posted on 15/6/07 at 10:08 PM Reply With Quote
It's the 1.9 Deseasel..........
Catpuss
posted on 16/6/07 at 12:42 AM Reply With Quote
Just turn the stereo up
rusty
posted on 16/6/07 at 08:41 PM Reply With Quote
How many miles has it done.
