Author: Subject: Bell Housing To Gear Box Torque
rusty
posted on 16/6/07 at 10:38 AM Reply With Quote
Hello
Can anyone tell me the torque rench setting for the bolt which hold the bell housing on to a type 9 gearbox.
Jed
posted on 16/6/07 at 11:05 AM Reply With Quote
These are the figures from my Sierra V6 Haynes manual with the Type 9 box:
Bell housing to gearbox = 70-90Nm (52-66lb/ft)
Bell housing to engine = 40-51Nm (30-38lb /ft)
andyharding
About that tight
zilspeed
posted on 16/6/07 at 12:21 PM Reply With Quote
it's at the high end of the scale on your torque wrench where the numbers stop.
It's marked FT.
rusty
posted on 16/6/07 at 12:37 PM Reply With Quote
I have had problems with FT i have found FT can = brocken bolts.
Jed
posted on 16/6/07 at 01:30 PM Reply With Quote
A good source of bolt info can be found here:
http://www.metricmcc.com/techinfo/overview.aspx?item=2
Well worth checking out just how much torque you can apply to some bolts.
martyn_16v
posted on 16/6/07 at 09:10 PM Reply With Quote
Could you be confusing FT with hhhhhhhhnnnnnnnnrrrrrggghhhhhhhomigodijustfollowedthrough?
